Question about Archos Gmini XS202 MP3 Player
I went to turn on my mp3 player, and it has just frozen on the welcome greeting screen. what do I do, as there is no power on or off button, only a pause and play button, which is used, when held, to power on or off. Also, plugging it into the computer, did not cause an reaction with the mp3 player.
Posted by killiankav12 on
Robert Keeler
    New Friend:
  • 21 Answers
Is there a battery that can be removed? that way you could do a "hard restart"
Posted on Jan 19, 2018
2 Related Answers
Anonymous
SOURCE: mp3 player has no music
Hi - I have the same problem. The tech support folks at Exmprex say you need to reset the firmware with a utility called fwisp.exe - which is on the CD that came with the player - except there was no CD. I've asked them if they can provide a downloadable version. Email [email protected] with your device details and see what you get.
Nick
Posted on Jan 11, 2008
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: unit will turn on to welcome screen but will not
Welcome to Fixya. If the device is freezing, recovery screen won't work and the computer will not recognize it. It's obvious that the player is bad. It is very common to a bad usb device that if the computer will not be able to detect it. If you can check the warranty of the device and contact Archos fro possible repair or replacement so that it would be free.
Thanks
Posted on Aug 11, 2011
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
New Coby MP822-4G MP3 player frozen on Welcome screen
I tried to contact Coby via their website email links (General and Techsupport) to no reply. I returned it for a full refund to the store and bought a Emerson. That worked.
Oct 20, 2009 | Coby Audio Players & Recorders
Screen frozen and slid bar is locked
Hold the lock and home button until the apple sign shows up then start over.Your welcomed
Sep 02, 2009 | Apple iPod touch
Frozen and stuck on screen disconnected
Hold the power off button continuously for 15 seconds. This should force a shutdown and reboot.
Apr 21, 2009 | SanDisk Sansa e260 MP3 Player
My mp3 frozen on the welcome screen and restart and freeze again
First reset the Sansa e260. The way you do this is you hold down the power (menu) button for 15-25 seconds. This usually solves it.
Good Luck,
Fixer Guy
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
My sansa mp3 just froze in the welcome screen when you turn it on
Try these steps:
SOLUTION 1
 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 22, 2009 | SanDisk Sansa m240 MP3 Player
Screen frozen cannot turn player on or off
Well, mine was frozen, and wouldnt respond to anything i was doing. so it wouldnt turn off. I let it stay on all night, but in the morning i went to it, and it was dead, so i went and plugged it up to charge, once it got a little battery, I turned it on, and it worked perfectly fine. try thisss(:
Jul 23, 2008 | Insignia NS-DV2G MP3 Player
Frozen !!!
Press and hold the volume up + key and the select button to perform a "hard reset" Best of Luck.
Aug 22, 2007 | SanDisk Sansa c150 MP3 Player
Sandisk e250
Turn off the player after turning it off. Perform recovery mode ( Enable hold switch + Press Record button + Power/Menu button ) until it says welcome to recovery mode and perform the update for the player. Then after doing that you may have to format the player. :D
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
My lyra wont turn on
Take the battery out and then put it in again and it should work again
Aug 15, 2006 | RCA Lyra RD2820 20 GB MP3 Player
Archos Gmini XS202 MP3 Player Logo
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
