Question about Whirlpool ET8WTKXK Top Freezer Refrigerator
Whirlpool et8wtkxk refrigerator Need to know how to replace water filter Need to know if there is a filter bypass
Posted by dotglock on
John Tripp
  • Whirlpool Master
  • 4,656 Answers
Replacing the water filter instructions are on page 10 here=> ET8WTKXKB00 User Manual
and here is a=> ET8WTKKB00 Parts Manual If you have any other questions please ask, Thanks, Sea Breeze
Posted on Apr 14, 2011
How can I bypass the fridge water filter on my Samsung RA4287HAR refrigerator?
I know your model is Samsung but on whirlpools when you remove the filter it automatically bypasses the filter through the filter housing I would try that with someone that can turn the water off before you do it just in case I'm wrong about Samsung removal of the filter should allow it to automatically bypass otherwise you will have to buy a I believe a 5/16 Union and just bypass the two lines in and out where you can reach him on the outside
Appliance 911 Sea Breeze
Dec 02, 2015 | Samsung Refrigerators
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
Replacing the Water Filter
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
Replaced water filter on a Maytag refrigerator it uses whirlpool filter. when filter is replaced and you try to use the water dispenser you get a loud grinding noise from the filter, how do you fix this?
I need to know which model you have, because i would explain the issue you have better. I thin it would be a MSD model and it could mean a board collision in the touch panel to the dispenser.
Please let me know your model so I can help you further.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 01, 2013 | Whirlpool Refrigerator Water Filter
Whirlpool top freezer fan not runnning and no voltage to the fan with the compressor running
This refrigerator has a basic wiring diagram showing power going through the defrost timer, compressor and compressor start components. Because the model number could be very close to the ET8WTKXK your model may have either a ADC, adaptive defrost control or typical 482493 Defrost Timer
Here is a Whirlpool ET8WTKXK Top Freezer Refrigerator basic wiring diagram.
sea_breeze_121.jpg In this photo you may have bad contacts inside timer part 4 in photo=> ET8WTKXKB03 Controls Ethier way I don't think it will be hard to find, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool ET8WTKXK Top Freezer...
Relay of my fridge blows off each time i replace
There is a dead short on the compressor which is drawing too much current through the relay hence the heat and the blowing etc.
You need a new motor
Aug 25, 2009 | Whirlpool ET8WTKXK Top Freezer...
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Can't change filter without water pouring out
Hi, If you can't shut the valve off to the water source, you will need to shut the water off to your house and change both the filter and the valve to the refrigerator.
When changing the filter, you will get a little water while removing the filter but, not very much. I hope this helps you.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Whirlpool GS6NBEXRB Side by Side...
Filter bypass for lsc26905TT
locate water filter bracket(normally in fridge compartment), then use screwdriver to remove from the frame. You will see two plastic pipes connected to this bracket. one will be water in and the other water out. pull the two off the bracket and join them together. (be inventive). Connect your RO system to the main inlet after original water supply is removed. Remember, your "filter to be replaced" light will still flash after a period as the fridge has its own software, counting depressions for cartridge replacement. (you would painstakingly have to reset.}
Jan 25, 2009 | LG LSC26905TT Side by Side Refrigerator
Whirlpool ET8WTKXK Top Freezer Refrigerator Logo
228 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
