HP Photosmart C3180 All-In-One InkJet Printer Logo
Anonymous Posted on Apr 14, 2011
My ink is 92 black and 93 color would i also beable to use 94 & 95 ink in it?
Jeremy Ness
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Apr 14, 2011
Jeremy Ness
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
22283
Points
251
95 Jeep Wrangler wiring harnesses broke down by color to show where each wire goes to
Car Radio Constant 12V+ Wire: Red/White Car Radio Switched 12V+ Wire: Purple/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/Red Car Radio Dimmer Wire: Red/Black Car Radio Antenna Trigger Wire: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 4? x 6? Speakers Front Speakers Location: Dash Left Front Speaker Wire (+): Gray Left Front Speaker Wire (-): Yellow Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Brown/Red Rear Speakers Size: 4? Speakers Rear Speakers Location: Rear Roof Left Rear Speaker Wire (+): Gray/White Left Rear Speaker Wire (-): Brown/White Right Rear Speaker Wire (+): White/Black Right Rear Speaker Wire (-): Brown
Starter turns slow
First make sure the battery is good and has a good charge. Next make sure the battery terminals are clean and are tight. If that doesn't fix the problem remove the starter and take it into a parts store like Auto Zone and they can bench test it to see if its bad.
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
1helpful
Keeps beeping and saying f90
I found this, hope it helps:
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Oct 25, 2012 • Ovens
Frigidaire oven error code
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
7. If all situations above do not solve problem, replace EOC.
Accessories For Audi
Jun 12, 2012 • Ovens
1helpful
F90 flashing
Hi Cathy:
F90 Maximum oven door unlock time exceeded.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
F90 is a door lock code, Try this...
- unplug the range and wait 1 minute.
- turn the range back on, then while holding in on the oven door.
- start another self clean and wait 2 minutes, then cancel the self clean.
Do not release the door until the door lock light goes out.
Hope this helps.
1510 black cartridge can print how many pages
There are 2 black cartridges which can be used in PSC 1510 ie 92 and 94
92( 5.5 ml) can print around 210 pages if its being used with HP 93 ( Tricolor) cartridge
94(12 ml) can print around 470 pages if its being used with HP 95 ( Tri Color) cartridge
You can also check it on HP Website click here to check on HP
F93 code (door not locking) tried to 'reprogram' by leaving unplugged for an hour, worsened the situation. Now when repowering, it immediately attempts to lock the door, obviously unsuccessfully and throws...
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
unplug the range.
wait 1 minute.
start another self clean.
wait 2 minutes.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&^%$
1helpful
Frigidair Electric stove (MN) CFEF358EC
3answers
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
k24674
Grand Canyon Tech
Grand Canyon Tech
