SOURCE: i need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Testimonial: "thank you, that was very helpful"
SOURCE: Hi How do you remove the child lock on a Bosch
Hi
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Thanks for contacting fixya.com
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
SOURCE: Change language to English on
Go to this address and it should allow you to download a manual, I got as far as the authorisation page.
http://gigabitdownload.com/signup/bosch_logixx_8_manual.rar
