Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive Logo
Question about Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo Drive
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I have downloaded firmware from dell.co.uk for the drive but when run this does nothing. There are no cd-rw or dvd drivers available on windows xp. Please help
Posted by s_wildeman on
Anonymous
  • 902 Answers
Those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Posted on Apr 14, 2011
My TSST corp DVD RW TS L632D ATA Device is missing ...and my laptop(dell inspiron 6400) cant read dvd. solution please
1.If device missing, try to restore system setting your windows or try to reinstall your windows
2. If your DVD can read dvd , maybe optic of your dvd rom is broken.
In this issue, dvd just read cd not DVD !
Ok that it, if the problems persist , just contact me, i will help you my friend.
1helpful
My samsung combo drive TSST corp CD/RW/DVD TSH492B cannot read some dvds even free from scraches but read some dvds.Bro please help me and guide how to remove this problem.
When a drive starts having this problem you need a new drive. Your drive is failing. They are very cheap online, only $20-$30 from NewEgg or Amazon.
I cant read write CD or DVD throgh TSST corp CD/RW/DVD TSH492B drive, Some error is getting, DVD is working Sadik
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
4helpful
Dell Optiplex 755 machines - TSST corp L632 drive-won't read CDs.
make sure that you are closing the CD and also make sure that the cat isnt licking the dogs balls while your doing it.
DVD-ROM and DVD+RW
Did you do a system "Restart" after the driver install? Sometimes that is all that is required to enable the device to work.
5helpful
TSST corp CDRWDVD TSH492B - DVDCD-ROM drive not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
2answers
Cd rom drive
Hi
Please use the Cd/Dvd Drive with the following specification:
CD-ROM/DVD-ROM/Disk drive
8X max DVD+/-RW Drive with DVD+R double layer write capability
Or
16X DVD-ROM drive, 16X/10X/40X CD-RW drive
Regards
ELLIN
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
