Question about Moyer Diebel 401HT Dishwasher
We have Moyer Diebel model 401HT, serial #w2384. The water is not draining out.
    Problem Solver:
  • 13 Answers
The drain flap/mechanism could be faulty or the hose in the back does not have a high enough loop and is siphoning back into the dishwasher.
Posted on Apr 22, 2011
  • Moyer Diebel Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Apr 14, 2011
How do you delime model 401HT-70 under the counter dishwasher
Best way is to contact a chemical supply company and have them do it. The delime product should not be mixed with chlorine.
Aug 14, 2013 | Moyer Diebel 401HT Dishwasher
Moyer deibl 401 ht overheaing
possibly the thermostat needs replacing
Jan 04, 2012 | Moyer Diebel 401HT Dishwasher
Hi...where do you put the soap in for the model 401HT?? It's second hand and I can't for the life of me figure out where it goes. :) Help!
If the machine still has a detergent pump, then the hose could still be taped to the back of the machine, half way up on the outside. It would have a label on it that says detergent. If the pump is missing then use a commercial grade powder detergent if your health inspector allows it. You would have to put in approx. 1 tablespoonfull each load.
Jun 05, 2011 | Moyer Diebel 401HT Dishwasher
Need to purchace a booster tank for 401 ht moyer debel where do i look.
A service man might have a used one kicking around. Or buy new.
Feb 26, 2011 | Moyer Diebel 401HT Dishwasher
The temp of the water is 200 degrees.How do I turn it down to 180
If the temperature was ok before, and no one has adjusted the thermostat, then that is an indication of a thermostat that needs to be replaced.
Dec 29, 2010 | Moyer Diebel 401HT Dishwasher
Moyer diebel model 301HT - water does not drain out
Could be the drain hose is kinked or partially blocked
May 12, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
New install, used machine, need an old manual.
I'm too late for you but others could be helped. With the power off' make sure the timing cams are set to the beginning of cycle, Then push the cams with a finger untill the fill cam switch just activates. Then put the power on,close and latch door and water should enter the booster. You might have to do this 2 times to get water at correct level inside machine. When the cycle lite goes off check for water inside machine. If water level is too high, then take some water out with a cup.
Jan 19, 2010 | Moyer Diebel 401HT Dishwasher
Moyer diebel 401 ht not reaching temperature ????
could be a number of problems. Checking with an ohm meter would determine the problem. Could be the booster high limit thermostat, a burnt wire, booster thermostat, or a heater element.
Oct 11, 2009 | Moyer Diebel 401HT Dishwasher
Dishwashers Logo
299 people viewed this question
Top Moyer Diebel Dishwashers Experts
GPEC
Level 1 Expert
Phillip Cushnie
Phillip Cushnie
Level 1 Expert
Tom Chichester
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
