Question about Panasonic CQ-HR1003U CD Player
My stereo was working just fine, playing all of my cd's easily. Then all of a sudden one day, it won't play any of my cd's. I keep getting the E2 error everytime I put in a cd! a brand new cd.. E2. I know that means it can't read it, or it's scratched, but I know the cd's are not scratched.
Posted by sharpie07 on
Dayton Computer
    Master:
  • 669 Answers
The laser beam at the tracking head may have been disrupted. That means the CD's are just fine, only the read head will not function. Unfortunately, the cost to repair is more than an replacement. Get a cheap $20-30 portable CD/DVD player at Walmart.
Posted on Feb 11, 2018
5 Related Answers
Anonymous
  • 440 Answers
SOURCE: What do I do with an E2 error?
maby way your buring them what brand uusing
Posted on Feb 04, 2008
SOURCE: E2 error
Ponle un disco limpiador de laser a ver si esto soluciona tu problema si no es asi tienes que abrirlo y limpiar al laser con un cotonete impregnado en alcohol primero lo limpias con el lado mojado y despues lo limpias con el lado seco el laser es un pequeno cristal como ojo de pescado.Suerte
Posted on Apr 09, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: panasonic cq-DFX444LEN
The heat is normal due to the large output IC's Panasonic uses. You need to get a "Laser Lens Cleaner" one that uses fluid. You can find them at just about any retail store these days for 15-20. Run it thru a couple times and hope that's the magic bullet to fix the issue, otherwise it needs service at a cost of 100-150 on average. If the cleaner does the trick, make it a habbit of cleaning your player every 3mos or 3000 mi. It truly is the best preventative maintanance on any CD/DVD/PC etc.! Hope this helps
Posted on Jun 24, 2009
tbirdfan1
Michael Thomas
  • 3053 Answers
SOURCE: My cd player in my car won't play cd's now. When
Hello there:
this means that it cant read the cd rom , because of the following conditions the cd rom is scratched or dirty or that the lens on the player is dirty and is in need of cleaning or that the player has failed all together
ok so try to clean the player with compressed air and a cd cleaner with some cleaner on it first than make sure that the cd rom is cleaned and not scratched and if still nothing is working you might want to consider a new player ok? Hope that this is very helpfull
best regards michael
Posted on Oct 23, 2009
Libran Moreno
  • 126 Answers
SOURCE: it wont play cd just keeps saying e1 eject cd radio plays fine
look for areset botton if it dosent have one by a cd cleaner if after that its the same replace the radio
Posted on Jun 12, 2010
How can I get my RCA 5 disc CD changer stereo to work right?
I have an RCA 5 Disc Changer, purchased at Target. The first one had a prolific issue of skipping on discs. It would play part of song on the first disc then suddenly change to the next disc. However, it did not ALWAYS do this, just sometimes, seemingly at random. Then one day, it would suddenly work just fine on all 5 discs. Eventually it simply would not play an entire song at all, so I took it back (within the time of the warranty). They had 1 of the same left on the back shelves so was able to get that one. This one started doing the exact same thing within the month. Now, it will not READ discs. It will simply read, 'Read"..and then when it comes up showing the disc number it has all zeros. I tried skipping to the next disc and then the next, and suddenly it read. That was fine for two days, then it would not even do that. I tried using compressed air inside all of the open disc drawer, and on all the discs but to no avail. Just now I tried tilting the entire unit Back at about a 30 degree angle and while in that position hit the 'disc change' button on the remote and suddenly it read. How long will this work? Have no idea. Very irritating - and it's hard to find this kind of player anymore, apart from a Component System which is a whole new playing field. Amazingly , I had bought my first changer, a 6 CD changer, cheap one at wal mart long ago and it lasted me about 10 years and never had a problem. It was a no-name brand too, I would expect better from RCA but alas, tis not the case.
Jun 05, 2014 | RCA Audio Players & Recorders
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
My jvc home stereo won;t play
It is the fuse, or the power transformer that in some cases has a built in thermal fuse in place of the regular fuse.
Mar 10, 2012 | JVC MX-GA77 CD Shelf System
My stereo won't come on an i can't seem to find the 4 fuses i need
It is the main fuse, or the power transformer that in some cases has a built in thermal fuse in place of the regular fuse.
I have a RDS stereo and it won't play my cd's. It says player error
RESET YOUR PLAYER AT DEFAULT SETTINGS. SWITCH IT OFF. SWITCH IT ON AND INSERT CD. GIVE THE PLAYER TIME TO READ. DON'T PRESS ANY BUTTONS TILL IT COMPLETE IT'S READING. IT WILL PLAY THE CD.
ALSO CHECK CD'S ARE BRANDED AND NOT COPY FROM COMPUTER. FEW COMPUTER WRITE CD NOT HAVE AUTO PLAY OPTION.
IF PROBLEM NOT SOLVE PLEASE INTIMATE.
Oct 07, 2011 | 2002 Buick Rendezvous
Playing MP3 Via AUX comes out crackly
Try turning the volume lowwer on the mp3 player and higher on the head unit. The radio is trying to amplify an amplified sound which is why you are getting distortion.
Mar 22, 2010 | Car Audio & Video
CD's play in Media Player but not Home/Car CD player ?
If you are using windows Media Player to burn the cd you have to burn to an audio cd. You can only burn to mp3 cd if your car or home system canread them. Wma audio cannot normally be read by car or home audio. The file format is called WAV
May 14, 2009 | Dell Dimension 3100 PC Desktop
Sony mhc-GX450 mech error
unplug the system.take out any extra speakers,and try plugging it back in.
Feb 24, 2009 | Sony MHC-GX450 CD Shelf System
Honda car stereo
I won a 2004 Honda Civic.
I had a bad battery and my car would not start. I had someone jump start it and it now has a new battery. The car runs fine but the stereo will not play am/fm or CD's. Regardless of what I do I get an "Error E code"
Please help.
Bob
Jun 15, 2008 | 2004 Honda Accord
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Panasonic CQ-HR1003U CD Player Logo
Top Panasonic Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
