When you power up the computer press F8 key then enter in safe mode note down the drive letter like f: then go to command prompt and type "chkdsk f:" without "" where F: assume as your drive letter. then follow below. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
If you have completed the above checks and procedures and the drive is still not properly detected, please attempt to use Seatools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
The problem is not related to my computer detecting my Fujitsu USD drive, the problem is in the Fujitsu drive itself... It has bad sectors (as revealed by some powerful data recovery softwares). Please note that I have already tried the below, and they ALL FAILED:
1) CHKDSK "F"/R (UNDER MS DOS)
2) LOW LEVEL FORMAT (SO THAT TO RECOVER LATER THE DATA)
3) FORMATING THROUGH PARAGON PARTITION MAGIC (SO THAT TO RECOVER LATER THE DATA)
any other suggestions?
Thanks
Lou
