Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
