SOURCE: i lost my software for my mp3 player help me
http://www.rcaaudiovideo.com/product.aspx?product=27&post=6
for software
for pc not recognizing-
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
SOURCE: I have a RCA Cd
It should play back burned cd's but this is not an mp3 player. This means you'll need to burn your books as audio cd format, and not as a data disc with mp3 files.
SOURCE: cd player is not working
?: Does the cd spins? If it does the optical eye that reads the cd could be dirty. Clean the eye with cd lens cleaner. If the cd is not spinning the motor could be bad. Also some cd players can't read certain disks because of the density of the disk. Make sure you read the manual to see what cds are compatible with your boombox. I hope these solutions were helpful.
Good Luck
George
SOURCE: Turntable won't turn
There is usually a cotter pin at the center of the platter around the spindle base. This can be removed with a screw driver using a twisting motion. There is a blades worth of space between the clip and the spindle base. Screw driver should be in vertical position. Sometimes the vinyl slip mat must be removed first. Watch that clip, cause it can go flyin. Once the clip is removed, the turntable should let go easily.
SOURCE: My RCA RS 2663 CD Player won't open when I push
you have to see how are the engem comections and if it receves power but do not open put a new one
