Question about Samsung HL-S6187W 61 in. HDTV
I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets about 270v from the power board, but the lamp never comes on. Could it be the ballast or the dmd board causing the problem? I can hear the color wheel spool up, but the beeping isn't consistent to be the color wheel.
Posted by Tom Fillmore on
Chi Chu
  • Samsung Master
  • 8,457 Answers
Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
Posted on Apr 14, 2011
Samsung HL-S6187W 61 in. HDTV black screen on the right side
There's a bloated capacitor on the circuit board. That one needs to be replaced.
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
Samsung HL-S6187W no picture, no sound, no start up jingle... Lamp is on, can hear color wheel turning. Already tried new lamp, new dmd chip, and new dmd board... Now what?
I have had issues where the digital board and also the analog board have been known to cause weird symptoms like that. Did the picture ever freeze any time before this isuue appear?
Oct 20, 2012 | Samsung HL-S6187W 61 in. HDTV
All three lights blinking, squeaky noise intermittent;no picture or sound
sometimes the color wheel will make that kind of noise good luck
Jun 13, 2011 | Samsung HL-S6187W 61 in. HDTV
No picture, replaced lamp on HL-S6187W. TV makes a audio sound when I turn it on. Lamp does not light.
Did you replace the lamp? Was the Lamp original? Some time if you dont replace the lamp with original you are going to have this issue. Is there any sound. If you have sound and no picture is the Color Wheel.
Thank you,
Nov 03, 2010 | Samsung HL-S6187W 61 in. HDTV
I have a SamSung HL-S6187W DLP whide screen tv
You need to replace the light tunnel.you will need to remove the lamp and color wheel along with the lamp housing and fan housing to replace it .If you are not comfortable taking things apart you might want a tech.
Nov 30, 2009 | Televison & Video
Samsung dlp hl-s6187w turns itself off after about an hour of operation. Once it cools down (5 minutes) it can be turned back on. what could be problem
check or replaced LAMP-BALLAST board
Manufacturer Samsung Part Number BP47-00037A Description LAMP-BALLAST;EUC 132
Nov 09, 2009 | Samsung HL-S6187W 61 in. HDTV
CABLE AND SATRELLITE TOGETHER
hook up the cable box to component # 1 or hdmi 1 and the satelite reciever to component # 2. i'm not sure if this model has 2 hdmi inputs,but you can also hook the satelite reciever to hdmi 2 if it does.
Jan 18, 2009 | Samsung HL-S6187W 61 in. HDTV
Cracked screen
Outside Viewing Screen with Grooves: This is a lenticular screen used exclusively with CRT
the Fresnel-lenticular screen would be a non-glare surface with vertical ribs, as shown here:
http://www.highdefforum.com/gallery/data/511/40Optawave-Diagram.jpg
Jan 10, 2008 | Samsung HL-S6187W 61 in. HDTV
Samsung HL-S6187W 61 in. HDTV Logo
253 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
