Hi, thanks for your answer. If I can correct the screen noise from your T-Con Board, I would eager to buy it from you.
Please name your price of T-Con Board for my TV set.
Thank you,
p.s. You can email me: [email protected]
SOURCE: T-con board for your samsung
The t-con board is very easy to replace. The only problem is you need to take a bunch of stuff off before you can get to it. How to replace it:
1. Take off the back of the TV
2. Unplug all the wires connected to the middle boards, you will need to take off the whole assembly that the 2 boards are attached to, the main power board and audio/video board.
3. The t-con board is under the shiny metal cover near the top of the TV. There are four small screws holding the cover in place. (You should be able to see the cover when you take off the back plastic cover of the TV).
4. There are 3 connectors attached to the board. The white one that comes from the audio/video board and 2 small ribbon type that connect to the front of the TV, probably the LCD panel.
5. The 1 separate connector is self explanatory. The other 2 are a little more difficult. They just slide into place. When you look at the connection, there is a brown "flap" holding the ribbon in place. You need to flip it up from the top side of the TV.
6. The old t-con board just comes out and the new one goes in.
Hope this helps!
Let me know if you have any other questions.
Ben
SOURCE: samsung ltm1755b dc cord missing/need replacement
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
