GE JES735WJ Microwave Oven Logo
Anonymous Posted on Mar 06, 2018
The post inside the microwave is not long enough to hold the roller guide in place. You can continuously push the guide down but the guide keeps popping up and will not rotate the glass dish. Any clues as to what can be done to make this work properly? Thanks for your time! Doug
3 Related Answers
tiway1
Tim martin
  • 100 Answers
  • Posted on Jun 30, 2008
SOURCE: Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Nancy_GE
  • 21 Answers
  • Posted on Aug 07, 2008
SOURCE: Microwave not working, please suggest
Your magnetron tube has failed. According to the warranty on the Profile Series microwave ovens, the magnetron is covered for 5 years from the date of purchase, but labor is not included. I would call GE Customer Service and when they ask for the model number (which begins with JVM) and the serial number, be sure to give the date of purchase as the date you closed on your house. If they insist upon charging you for a service call and labor, I would call my builder's Customer Service Department and demand (very nicely) that they intervene with GE to waive the service and labor charges. That worked for me (Lennar Homes).
Anonymous
  • 338 Answers
  • Posted on Mar 01, 2009
SOURCE: Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
My galanza microwave, air fryer, oven will not heat while using microwave and makes a terrible racket?
here are some items to check for troubled microwave
Bad Magnetron Symptoms What are some bad magnetron symptoms to watch out for?
The following is a brief list of some of the most common signs that your magnetron is about to give out:
Heating: Either the microwave is not heating up at all, or the heating performance has degraded noticeably.
Burning Smell: A burning smell (non-food related), may be an indication that elements of your magnetron are overheating. In this case, switch off your microwave immediately, and arrange for a repair or replacement.
Unusual Noises: All microwaves make a bit of a hum, but if it's become much louder - or sounds like unusual vibrations - your magnetron may need to be replaced. Watch out for a clicking sound as well - that's a tell-tale sign of a magnetron that's about to fail.
Is It Worth Replacing The Magnetron In A Microwave?
It really depends on the cost and age of your microwave. If it's somewhere between five and seven years old, you're in the right period of time for a replacement anyway.
There's little point spending good money on repairing or replacing a magnetron if the rest of the appliance is likely to give up the ghost soon anyway!
Symptoms of a Bad Microwave Diode? (Answered!)
A microwave diode is one of the most important components in the appliance. Without it, it's impossible to generate the heat required to heat foods and drinks placed in the oven cavity. Unfortunately, the component can go bad, so it's important to understand the symptoms of a bad microwave diode.
Generally, the symptoms of a bad microwave diode include sparking, buzzing and humming, and the appliance failing to heat. Running a continuity test helps to determine whether the diode has a problem. Getting a new diode for replacement is the solution if the current one fail the continuity test.
3 Symptoms of a Bad Microwave Diode The following table shows the summary of the symptoms of a bad microwave diode as well as what you can do to fix the problem:
Symptoms Solutions 1. Microwave buzzing and humming Inspect the diode, test it for electrical continuity, and replace it if it fails the continuity test. 2. Microwave not heating Start by inspecting the capacitor and magnetron because they may also be responsible for making the microwave fail to heat. 3. Microwave is sparking Locate the diode, inspect it, and test it for continuity. Replace it if there's no continuity. There aren't too many symptoms of a bad microwave diode. The most common ones include sparks & burning smells, the microwave not heating, and the microwave making humming & buzzing.
1. Microwave Starts to Have Heating Failures
Apart from a failed main control board, a faulty fuse cavity, a blown line or thermal fuse, and a faulty door switch, the high-voltage diode could also be the possible reason why the Whirlpool, Kenmore, GE, or KitchenAid microwave is not heating.
Your microwave failing to heat is a perfect sign of a faulty diode, which means you should get a new one for replacement.
2. The Microwave Starts to Pop Sparks
Sparks in your Kenmore, LG, Samsung, or Whirlpool microwave could be a sign that the high-voltage diode is defective.
Also, a burning smell from your microwave can indicate that the diode is bad. A burned-out diode can break into two, wear out, or short.
Immediately locate the diode in the cabinet next to the magnetron and replace it.
3. Microwave Starts to Make Noise
Your microwave could be buzzing and humming because the high-voltage diode is defective.
Apart from the diode, other components that can make your microwave make noise are the plate & drive motor, cooling fan, and magnetron.
Keep in mind that you can't repair a bad diode. You can only replace it with a new one.
Safety Warning
While repairing a microwave, the chances of falling into electrocution by the high-voltage capacitor even after unplugging the power cord from the socket are very high.
So you need to be very careful when doing the diode test.
To begin with, the high-voltage diode is located close to the high-voltage capacitor. In fact, one of its ends is attached to the high-voltage capacitor.
And as you know, a microwave capacitor carries high power voltages, which can be quite lethal. It is therefore important to start by discharging the capacitor before getting to the high-voltage diode.
Although the capacitor can store charge for a long time, touching both its negative and positive terminals with a metal screwdriver blade will drain all the charge in seconds.
Testing the Microwave Diode
Before you even attempt to replace the diode on your GE, Whirlpool, or KitchenAid microwave, do a functionality test to confirm your suspicion.
You can visibly confirm the diode is burned-out when you see physical damages.
In case there are physical damages, use a multimeter to test if the diode still has a continuous electrical path.
To test the diode for continuity:
Touch the positive and negative terminals of the high-voltage diode with the multimeter probes.
If the diode test negative for continuity on both of its sides, the diode has failed and will need a new one for replacement.
Microwave maiking loud noises
Tip #3: Weird Noises
. A high-pitched noise while the microwave is in use means there's a good chance the magnetron tube or diode is failing. If the exhaust fan or magnetron tube are the culprits, you will need to call a local appliance repair service.
DIODE HIGH VOLTAGE You might have an issue with the high-voltage diode if your microwave is generating an odd or loud whirring sound. This element, together with the magnetron and the capacitor, is a part of the high-voltage circuit. The cabinet needs to be taken out in order to get to the diode.
BUZZING AND HUMMING Most buzzing or humming noises are frequently caused by the fan motor, vent fan, magnetron, or any combination of these. This noise from routine operations gradually gets louder over time.
As the microwave oven warms up, the oscillation happens, and the fan helps keep the mechanical parts from overheating. You might need repairs if the volume of your microwave suddenly increases.
Try running the magnetron at a lower power setting while putting food inside to see whether the magnetron is the cause of your problem. This will cause the magnetron to switch on and off to maintain the proper temperature. If the magnetron is the issue, there should be less noise.
CLICKING NOISES Even though your microwave might not have a revolving plate, some models spin food using a glass turntable or plate. This component aids in ensuring even heating throughout your meal. However, occasionally clicking noises may result from this action.
If you constantly hear clicking, see if your glass plate, roller ring, or track needs to be cleaned. These are simple to clean with soap and water, but you might have neglected to do so. The location of the plate is what determines the other option, so be sure it is still on course.
POPPING As you prepare food or after spilling food, you might describe the sound of your microwave as popping, crackling, or snapping. However, these tones frequently come from dishes with significant water or fat content, particularly sauces.
POWERFUL SOUNDS When it comes to microwaves or other appliances, these noises continue to be the most alarming. You should replace your microwave if the device starts to make an electric-sounding noise called arcing.
If you notice that while using your microwave, the electricity flashes in addition to making a sound.
Stop using your microwave if this occurs and you notice a hole in the back o WHY DOES MY MICROWAVE MAKE A VIBRATING NOISE
There can be various reasons behind a microwave making vibrating noises. Some are given below.
POWER MOTOR Your microwave's drive motor may be malfunctioning if the turntable is making an odd noise. The majority of microwaves with glass trays turn the tray with a motor-driven coupler or a roller guide.
Access must be made through the bottom of the oven because the motor is normally found below the floor. Normally, a holding screw holds the motor in place, and two wires are connected to it as well. The motor must be replaced if it is creating a grinding sound.
its because it is now dangerous.
A loud humming or buzzing sound could result from a damaged magnetron
PUSH COUPLER If your microwave is making an odd noise, the drive coupler for the turning tray can be the cause. The majority of microwaves with spherical glass trays revolve around the tray on a roller guide using a motor-driven coupler.
A drive coupler with an offset center roller is sometimes used in models that employ a rectangular tray to move the tray guide from side to side. Remove the tray and roller guide from the oven for either style and then check the coupler. Before you can pull the coupler off the motor on some models, you might first need to remove the motor from the bottom.
ROLLER GUIDE If the turning tray in your microwave makes an odd noise while rotating, there might be an issue with the roller guide underneath the tray. A motor-driven coupler is sometimes used in microwave ovens with spherical glass trays to turn the roller guide.
2answers
The turntable stopped turning and when I press start, nothing happenes. The clock still works and the light comes on when opened but, nothing else.
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Regards.
Microwave just stopped turning, everything else works
Good luck.
1helpful
Turntable works intermittently
Good luck.
Turn table turns some of the time
Good luck.
Walesarumi
The turntable is not working but I have power
Good luck.....
The turn table doesnt work
Good luck.
Turntable does not turn
Good luck.
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
29helpful
2answers
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
