Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Hello, I have a Panasonic PT-40LC12 40 in. Rear Projection HDTV Television. One day I heard a "pop", and then the tv turned off and now will not turn back on, can you help me figure out what the problem is?
Posted by tony59941 on
Anonymous
    Scholar:
  • 79 Answers
Your lamp has gone out. replacement can be ordered online for about $175.
easy to install, plug and play.
Posted on Apr 14, 2011
Panasonic pt-53tw53 location of my stk chip
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Jan 06, 2012 | Panasonic PT-53TW53 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Heard a pop and tv went dead green light flashes then goes red
If you heard a pop, chances are that a component has shot. Check all components on the circuit board. main components to look out for are capacitors with bulging tops or popped bases. These are the cans with flat metal tops in them with a cross imprinted in them.
Only test electronic equipment if you are competent to do so. Electricity kills so electrical know how is important.
Feb 28, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Own a 52" panasonic rear projection tv. Heard a loud pop, and tv went out. Will not turn back on.
Power supply board is dead.Replaced power supply will solved this problem.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to replaced.
Feb 25, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
D board for panasonic tv
Hello
You can purchase TNP2AH046S d board at Panasonic Parts and price is approx $280
Sep 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PT-52LCX16
Hello swankymom, juancardenas,
Your both problem is a defective lamp. That is your only problem.
List Price $233
Part Number TY-LA1001
Best regards
circuitcity
Apr 13, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Dec 07, 2006 | Panasonic PT-53X54 53" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
