Question about Frigidaire FAH125P2T Air Conditioner
Front panel and remote not responding!
Not too long ago, I bought a Frigidaire air conditioner but the front panel on the ac is not working. Nor is the remote controller. Because of the problem, the way I turn on or off the ac is through the plug with the reset buttons. The ac itself works fine with cold air blowing out but since the control panel nor the remote is working, I can not change the ac to a different mode. Since the ac is new, I was thinking this is a minor problem that can get fixed easily. If anyone has any clue, please help out!
-ps : the ac is window mounted
Posted by exciter06 on
4 Related Answers
Paul James
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
Anonymous
  • 230 Answers
SOURCE: Can a window air conditioner fit in an exhisting wall mount?
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Anonymous
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
Anonymous
SOURCE: Frigidaire Model FAZ12HR2A Digital control pad
coils freezing
Posted on Sep 21, 2009
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
Control panel is not working
Does this unit have a remote? If so, try to use it, does it work then? If not, then the control board is most likely your culprit. If it does work, then possibly a button on the control panel is faulty.
Jul 21, 2012 | Frigidaire FAC127S1A Air Conditioner
AC does not start
I just bought this unit today an I'm having the same problem as you
Jul 02, 2012 | Frigidaire FRA256ST2 WallWindow Air...
Have an LE room air conditioner, the remote control won't work - new batteries and the manual control on the front panel won't go below 85 for the temperature setting
electronic module of ur ac is not working,try to remoove it carefully (only if u can) and heat all the soldered jointes with a 25 watt soldering iron,by doing so it should work if not then replace the module
Jan 08, 2010 | Fedders Appliance Air Conditioner Wall
Frigidaire FAH125P2T Air Conditioner Logo
212 people viewed this question
Top Frigidaire Heating & Cooling Experts
Bill Long
jasbo
jasbo
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
