Question about Brother MFC-9440CN Laser Printer
Mfc 9440cn. paper is jamming (rear). changed paper, added paper. indicates the jam has cleared but is again jamming. i have had this happen on an old laser jet 4 and had to replace the rollers. any suggestions to solve this problem.
Posted by pgreen1950 on
SHAKEEL KHAN
    New Friend:
    Problem Solver:
  • 6 Answers
Printer needs servicing.
Posted on Apr 13, 2011
Paper keeps jamming
dear friend this printer is brand new/ old. if old how much old?
Jun 27, 2013 | Brother MFC 7840W Printer
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 9940cn paper in try not feed or rolled forward, paper jams
open the back cover for paper jam and check is there any foreign object is present then remove that it and start printing
Sep 10, 2011 | Brother MFC-9440CN Laser Printer
Brother MFC 9440CN - I am getting "Document Jam"
Take the cover off of the ADF, rub clean the rollers with a damp cloth. Make sure there is no paper stuck in the area Also, check that the sensor flags are activating. just move them back and they should bounce back to normal position. Cleaning should do the trick.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 21, 2011 | Brother MFC-9440CN Laser Printer
Printer jams frequently. Jam is in the paper tray. It appears to try to pick up a sheet of paper and can't. When you open the paper tray the sheet of paper has been lifted up, but not enough to pull it...
Locate the paper lifter and the initial rollers and clean these with isopropil alcohol and a Q tip. These items become hard and polished and will not grip the paper properly, causing the jam.
Jan 20, 2011 | Brother MFC-9440CN Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Paper Jam
Have you checked for paper jammed in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
Jan 13, 2010 | Brother MFC-7820N Printer
Paper Jam
You need to try clearing the paper using a airblower if you do not have a air blower try with a vacuum cleaner, surely it cleans up. Unless until you remove the paper it shows the msg.
If you think you have no other option and you tried everything its better to call some service guy and get it done.
Regards
Oct 03, 2009 | Office Equipment & Supplies
Brother MFC-9440CN Laser Printer Logo
467 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
