Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
SOURCE: Need Dynex DX-E402 Firmware
if i find a compatible firmware i will send you an email right away, although I cannot guarantee that i will be able to get the exact firmware, but i will try.
SOURCE: No internet connection threw Dynex DX-E402
Hope this helps!
SOURCE: My Dynex 4 port router will not communicate with my DSL modem
Have your router clone the MAC Address of your computer. The MAC address is a hardware address on your network card and DSL providers seem to like to bind it to account. What is probably happening is when the router connects to your ISP and asks for an IP address, it looks up your account info and and decides - nope, wrong device. Cloning the MAC address will make them happy. If you are not able to clone the address, call your provider's tech support and ask them to clear the MAC address from your account. Make sure you have the router plugged into the modem and not the computer or you are back to where you started.
SOURCE: dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
SOURCE: how do i set upa dynex dx-e402 i have a verizon
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
I do have a guide for that.
Once that is done you should consider giving out proper IP addresses
Big business does this for security and reliability and it is no different for home users except maybe easier
Read the guide for router and modem first and if any of it may apply to you then try and do it.
The second part deals with IP addresses and this may well help you
I have a selection of computers laptops servers at home on a small network
It is quite some time since I last had to do any sort of system wide shutdown
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Take note of the DEFAULT GATEWAY
Now do the same thing with your ROUTER
If that too has the same IP as your modem in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
