Roland Cammjet 500 will print magenta initially and then stops after about 6 inches. A pause and a clean (clean only needed some of the time) will bring back a complete nozzle check and you can print again but after 6 inches it stops again and you need to repeat the process to keep it running. We have changed the cartridge, put new heads on, new dampers, checked all the lines and we can not solve the problem - any ideas?
Posted by smartinkjet on
  • cnsign Nov 05, 2008
    I have a similar problem with my Roland Cammjet 400, but it is with the yellow ink. Initially, it will print about 20 inches of complete color, but after that, it stops printing yellow. I too have tried head cleaning and changing the dampers, but the problem persists.
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Power-on "initializing" power-off, repeat same cycle(process)
The all-in-one product display always reads "Initializing" This may occur in a low power situation. Follow these steps in order to determine the cause:
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  3. If the all-in-one has an ADF with an external cable plugging into the back of the product:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable, and turn on the power.
      • If no change, the problem is not the ADF.
      • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
      • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  4. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
Posted on Jan 15, 2008
Anonymous
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
Anonymous
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
John K
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
Anonymous
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Posted on Mar 12, 2009
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
I wish to clean the colour printing. I've cleaned
hello mvn 500 your printer is a inkjet say yes please remove the your colour catridge or laser printer please change the magenta ink only because laser was a 4 colour option cyan, magenta, yellow and black
Jul 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Mag & Yel Ink don't work
replace ALL carts with new ones.
press menu then start bk-copy then fourtimes arrow up quickly one after another. machine turns to maintenance mode.
press 7 then 6 then 4 then start bk-copy.
machine will initiate the carts and refresh ink in tubes and ph and do some special power cleaning.
when finished press 7 then 6 then 3 then start bk copy.
machine will do a power cleaning.
when finished press 9 then 9 to leave maintenance mode.
run a test print.
If you cant see any yellow and/or magenta the ph is defective and needs replacing (this happens mostly because of generic ink which contains the wrong chemical mixture to keep the ph alive).
Mar 24, 2008 | Brother MFC 420CN All-In-One InkJet...
Will Not print magenta
hmmm...even on a test print page?
Feb 24, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer won't print magenta
So what does the machine do: Not recognizing the cart (error: insert magenta) or does it not print onto the paper?
In 1# case: Reinsert the magenta cart and make sure that the support is secured above the cart top. If it is recognized: OK.
If not unplug mfc from power. take all carts out. Wait five minutes. Reconnect machine to power. wait until machine demands carts. reinsert cart as demanded and give the right answers (see display).
Machine should run a short cleaning cycle.
In 2# case: Insert full carts well. press menu then start mono (blue) then fourtimes arrow-up (te-index). machine will be in maintenance mode. press 7 then 6 then 4. machine will initialize the carts. after some cleaning cycles machine will be
in mentaenance mode again. Press 9 then 9 to leave mode. press ink etc. to run a test print. If it fails and you cant see any magenta, the valve or filter is clogged and cant be fixed anymore.
Nov 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
169 people viewed this question
Ekse
Marvin
Marvin
