Two of the wires are ground (-) and two are hot/signal (+). You'll need a stereo 3.5mm mini plug (try your local RS...they also call them 1/8" plugs). The stereo plug will be divided into three separate connections called Tip, Ring and Sleeve. The Tip is right channel signal, the Ring is left channel signal and the two grounds should be connected to the Sleeve or ground connection.
If you get one side of your headphones backward (out of phase, plus and minus backwards) you'll know by the sound quality and so reverse the wires of only one side to correct.
Testimonial: "Thank you!"
