SOURCE: For the ID Armor ID-XC200D, where should I place
You don't use liquid oil. At the office supply stores they carry oil sheets that you insert just like shredding something. They come ion various pkgs. Staples and Office Depot stores carry them. They are universal, no model number needed. I hope this helps.
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
SOURCE: I was given an ID Armor 1506x shredder, it
Hello
If the shredder only works in reverse,this indicates a blockage somewhere.The sensor at the center of the shredding console must be engaged to activate the forward shredding process.
Clear any blockage by placing the power switch in "Auto" and pressing the "Manual Forward" button for about five seconds
SOURCE: motor is burned up, would
Have seen many people looking for parts for these small shredders here on fixya....have not seen that you can buy parts anywhere yet...
They really don't want you to fix them I think, they want you to chuck it and buy new...
heatman101
