SOURCE: Web cam problem
ya vista have some problems go to your internet option and download manually the latest update of your webcam .this may be a problem because u are using latest version of yahoo but your web cam do not support it or either add xp also in ur laptop.
SOURCE: Camera assistant software not working
Please help.... to troubleshoot this problem re: toshiba satellite L310 web camera doesn't work. the light blue color sensor display but appear only black screen.
SOURCE: black screen on web
what IM are you using? It could be some settings in the IM or it could be forcing it to behave such. go to Tools->Options->Video settings. there select this webcam as your default webcam. as far as the black screen is concerned, go to settings of the webcam and check the contrast and brightness settings. adjust them both to your liking.
SOURCE: Brand New Toshiba Laptop Screen won't come on
That state might called comatose, during the shut down the battery gone low, so the system is in a hang state, after recharging to its full, then you power it on and the system try to recall the last status,sometimes needs reset and the system will work, other trick is remove the battery and PSU then push power switch several times to drain residual power and attach the battery and turn power on.If this will not work, the bios might be need reset, in this case you must claim your warranty service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
