I am using the magnavox zv427mg9 digital video disc recorder with video cassette recorder. I recorded a two hour block of a certain half hour TV show and am trying to create 4 30 minute titles from this two hour title. I followed the instructions in the manual, which say to get to the edit menu, find where you want to create a new title, and then select "Title Dividing". However there is no option called Title Dividing on the edit menu. Obviously something is wrong! How can I fix this (or is it fixable at all?)
Posted by vanesjr on
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: All DVD`s installed in player skip .Also DVD`s that showed title donot now.
first thing i would do i clean the lens with 90% isoprople alcohol and a q-tip, if that doesn't work watch the laser eye again and the movement is the laser look like it tries to catch up???
i would put a dc volt meter on the motor and the motor should stay at lower voltage if it climbs then there is something with the rails or worm gear. let me know what you find out.
Posted on Jan 04, 2008
Anonymous
SOURCE: recording problem
You probably have a ZU unit (label on bottom) unlike the MU1, the ZU always asks to finalize before removing the disc, even on RW. Try leaving more blank space on the disc, sometimes allowing the recording to go too long also makes it throw a coaster.
Forget the list, stick to RW if you can, it will still ask you to finalize, and you will have to let it finalize it before removing it (again the MU is different and I don't have to finalize rw in order to play it in my computer) I like the MU1 so much better.
Posted on May 21, 2008
Anonymous
SOURCE: DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Posted on Jan 14, 2009
Anonymous
  • 7 Answers
SOURCE: Will not play Quantum of Solace
go to your player manufactures website and download and install the lastest firmware for your player.
New BD movies have more functions and features which require you to update your players software to play them.
Posted on Apr 26, 2009
Anonymous
  • 666 Answers
SOURCE: Sony rdr-hx715 says cannot record this
if the disc no longer loads on your computer with the data it was suppose to have been written too it may be a finalizing error and you would want to make sure you have all the updated drivers and are using compatible software for it. If after burning the disc it is not being read on other dvd players and is not being read by your own dvd drive on computer or player than it is definitely a hardware problem and will most likely need to be replaced or returned if still under warranty
hope this helps
Robb
Posted on Sep 05, 2010
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
    The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
    It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
    Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
    U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
    Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
    Hook up of magnavox zv427mg9
    I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
    Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
    I have a Magnavox ZV427MG9 A VHS & DVD Recorder
    U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
    can record tv shows now.
    Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
    How do I connect the Magnavox to my cable?
    If you are talking about the Magnavox ZV427MG9, this unit is a Digital Video Disc Recorder and Cassette Recorder. There are no connections for the RF cable (analog) that is normally connected to the back of the TV from the cable company or satellite receiver. However, you can use RCA connectors, S-Cable and other cables to connect to your TV if your TV has these types of IN and OUT connections available. Most TVs made in the past 5-7 years have these types of connections.
    Aug 14, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
    Interface SA-DX940 with Sony Vega TV and Magnavox Video Recorder
    you need an upscaler for the vision sound will be dolby stereo 2
    Dec 08, 2008 | Technics SA-DX940
    Televison & Video Logo
    412 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
