Try going to 192.168.0.1 try that one then type in your password or the default password which is always admin for both username and password. If this does not work then go and unplug the router for about 25 seconds and wait then plug it back in then go to the reset button and hit that quick and wait for it to reset then this will bring everything back to default value and you can try going to 192.168.1.1 or 198.162.0.1 and whichever works for you and opens up the username and password window type in admin for username and leave the password empty if that does not work then do both using admin for password as well and fill in the username with admin this should bring you to the router settings page. Thanks for using FixYa! Make sure the router is plugged in and working and hooked up correctly to your computer. John
Open a web browser.
Type 192.168.1.1 in the address bar.
Username is admin
Password is admin
Unless you changed your password to the router, in which case you will have to do a hard reset on the router to get all the defaults back. This means, more than likely you will have to setup anything that you had configured on the router before the reset.
If you are facing issue while you are trying to configure your router then there may be some technical issue. Do one thing, disconnect router from modem and do switch off power to the router. After a couple of minutes start it again. Router user name and password are same. If you facing issue with user name and password then you can get it from 19216811admin.info
Admin admin
