Question about Likom HD15A 15" LCD Monitor
I need to know if my lcd monitor Likom HD15A you can change the resolution d epantalla over 1024, I have SO please confirm W7
Posted by raul_artero on
Tom
    Novelist:
  • 120 Answers
The max resolution for this monitor is 1024x768.
Posted on Apr 12, 2011
Anonymous
  • 73 Answers
No, that is the native resolution of your LCD Monitor, it can not display a higher resolution.
Likom lcd autonatic shutdown
Sounds like a hardware issue. Make sure your settings on your computer are not causing it.
If its not your settings then it is a hardware issue with the monitor which sadly means you will have to send it to the manufacture or someone who does hardware repair.
Screen black with error message of bad resolution
follow theses instructions to resolve your problem :
- Restart your machine
- Press F8 rigght before Windows bootup
- In the menu select "VGA mode".
- Once your system boots, click with mouse right button on the desktop.
- Select Screen Resolution/Properties.
- Navigate over the windows, until you found the resolution categorie.
- Change your resolution to 1280 x 1024 or lowest one, 1280 x 1024 is Max.
- Press OK, and then confirme your choice.
- Enjoy.
THERE IS SOME FINGER PR INTS IN OUR LCD MONITOR WANNA ASK HOW YO CLEAN AND REMOVE TNE FINGER PRINT
The best way is to buy a special microfibre cleaning cloth for LCD monitors. Very often the same cloths are used to clean sunglasses so you may already have one of those. Do not use any cleaning liquid. Rub the screen very GENTLY with the cloth until the prints are gone. You can rub fast but remember not to press too hard or you can damage your monitor.
Computer monitor
NEED CHANGE THE LCD BOARD.
2answers
Need an Inverter for Likom HD15A LCD Monitor
Go links:
http://www.aitendo.co.jp/product/230
http://www.garitto.com/product/index/3804758#review
Inverter Board
http://www.pchub.com/uph/category/43/LCD-Inverter.html
Likom Futura LDF770
There may wrong setting of refresh rate. Most monitors work at 60 to 70 Hz refresh rate. Above that they tunned blank screen or out 0f range message displayed. Also check the output video signal. Please confirm technical specifications from the documentatation of the monitor.
2answers
The monitor cant view video
To use the external vga connector of a laptop, you have to activate it. In many notebooks it is Funtion and F7 (Fn-F7). In your notebook it may be F5 or F6, look for a monitor sigh in the F keys. The activation may sometimes rotate in sequence , ie, External + LCD, LCD, External... and so on.
3answers
Likom HD17A blacks out
Just check that your monitor is not set to power down(Control Panel> Power Options) and check that the 'Turn Monitor Off' Power Scheme is set to never and turn off any screensaver to see if it still goes off.
Likom HD15A 15" LCD Monitor Logo
Top Likom Computers & Internet Experts
k24674
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
