Question about Vector VEC1047BD 750 Watt Power Inverter
I have a vector 750 watt inverter (vec1047bd). The charge controller in my photovoltaic system went bad and I had it repaired. When I got the controller back, my inverter did not work. The inverter has a blinking red light and a constant green light. I moved the inverter to my car battery and I had the same results. Any ideas?
Posted by aarioch55 on
Steve Cox
    Master:
  • 674 Answers
If you have a manual for the inverter check and see ifDin there are diagnostic codes with the LEDs.
http://documents.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC1045.pdf
I looked through this and your description of the problem was not listed in the document, but you may be able to contact the manufacturer and get more information. Basically this is a DC to AC power conversion device, which takes the 12v DC input and converts it to 115V AC
and in does so at a maximum peak power of 750 watts at 115V AC. since your charge controller went bad, it is possible in the process it overloaded this device or the battery system put out too low of a voltage when the charge controller died and low voltage input is not something this unit was able to tolerate. Check your remaining components to be sure they are good, then look at the inverter's board and transformer to see if anything was damaged. I would want to verify the charge controller was good and the batteries in good condition - and perhaps consider replacing this inverter with one more suited to your actual load wattage requirements.
Posted on Nov 19, 2017
5 Related Answers
murat ustek
SOURCE: Puff of smoke
yes u got da inverter overloaded out puts r gone 2hot and fan couldnt cool it enough now this inverter basicly a amplifier amp does da same problem when da out put r blown yes i got da unswer
Posted on Mar 03, 2009
Anonymous
  • 7 Answers
SOURCE: I have a 400 watt vector inverter prower on board
yes if this is close to mine there is a cover over 2 feuses on the back
Posted on Jul 05, 2009
Anonymous
SOURCE: my vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Posted on Aug 15, 2009
nitrospawn
Ibe Chukwudi
  • 290 Answers
SOURCE: Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Posted on Feb 27, 2010
woozie38
  • 608 Answers
SOURCE: vector 2500 watt inverter red led fault light no
There is a fuse on these things at the back of the case. Could be in a slide out plastic holder, or in a round holder with a knurled screw or bayonet type cap. If this fuse is not blown, then the news is not good.
Posted on Mar 21, 2010
Circuit diagram
Proprietary info. Good luck on that
Oct 06, 2013 | Vector VEC056D 2500 Watt Power Inverter...
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
I bought two veco51d 3000 watt inverters made by vector and conectted with two positive and two negative cables to a good battery 12.6 volts load test at 750 cranking amps and both inverters light up and...
Hello, I hear you. Was the reason to supply 240 volts? When you try the inverters separately, do you get 120Volts output? Let us look at the units working individually first and go from there.
Feb 06, 2011 | Vector 3000 Watt Continuous 6000 Peak Dc...
I have a 750 watt Black and Decker inverter that will only start up when turned on but immediately goes to the caution light and does not charge anything. It worked for a short while, only a few minutes,...
or that your drawing too muc power, though 750W is a hefty supply. what are you plugging into it, is it grounded properly, do you have thick enought supply wires?
Jun 11, 2010 | Vector VEC043 750-Watt Power Supply
Bought a new vector maxxsst 1200 watt inverter
Inverter run on batteries sir, and if these batteries are not charged, the run time {the number of hours it will work} reduces.
S0, you will need to connect the inverter to a power source.Theses will allow your batteries to be charged and enable it to run for a long period of time.
Make sure your batteries are still OK.i.e working properly
May 03, 2010 | Vector ® Maxx SST 1200 - watt Power...
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
When I charge my jump starter, do I have it on or off for it to charge?
off, never leave it on, danger of short if the clamps touch metal, turn it on only when you are using it to help start a car
Jan 09, 2010 | Vector VEC 024 400-Watt Power Inverter...
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
I think my inverter burned.
it depends on what burnt in it, you should check it out to know
Jan 13, 2009 | Vector VEC 024 400-Watt Power Inverter...
Vector VEC1047BD 750 Watt Power Inverter Logo
227 people viewed this question
Top Vector Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
