Question about LG 30FS1D TV
HDMI module The hdmi quit working. The TV works fine through the components cables. I tried the hdmi cable on another tv and it worked fine. Where can I buy a hdmi module? I have a 32" LG Slim projection HDTV that i bought 2 years ago and have never been able to get the HDMI to work... see below. I have tried plugging in several HDMI cables and equipment (ie. PS3 and DVD player) to my TV.  I have seen the cables and equipment work on others TV so i know its not the equipment. Neither the HDMI connection or the coaxial HD connections will recognize a signal from my PS3.  I tried this connection when i bought the TV and it would not detect a signal then...  I thought i was doing something wrong so i connected the DVD thru the front regular coaxial (3 cable) connection.   so basically none of my HD connections will recognize a signal and the regular connections work fine. I really hope that there is something that i just need to turn on or format.  Any help is greatly appreciated.
Posted by Gouger101 on
5 Related Answers
Anonymous
SOURCE: Black and White !!!!!!!!!! aaaahhhhhh
As ther is no color & every thing normal. you have checked most of the things from outside. solution please check loose contact near chroma ic. check connector for loose. parts related to chroma section. finally chroma ic. good luck
Posted on Sep 20, 2007
Anonymous
  • 39 Answers
SOURCE: Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Posted on Dec 17, 2007
Anonymous
SOURCE: Protron HDTV Cable hook up
D4 is a Japanese HD standard, which is why it's almost impossible to find any cables with a D4 connector on it in the US.
I have the same Protron TV you're talking about, but it's been rebranded as Ultra. Did you not receive a D4 cable when you bought the TV?
If not here is where you can get the cable you need: http://www.igsshop.com/product_info.php?products_id=162
or here
https://www.digitalconnection.com/store/Product_List.asp?CID=3&CAT=D4%20SCART/COMPONENT
This should allow you to get HD signal from your cable box (granted you have an HD cable box) to your TV.
Posted on Dec 31, 2007
The Machine
Dean Joly
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
Anonymous
  • 6 Answers
SOURCE: bought a used lg ru52sz51d
It sounds to me as though your old HDTV has a HD tuner built in. Not all HDTVs do and unfortunately your LG does not (I looked it up).
If you want to get free over the air HD you will need to buy a HD digital tuner box and an HD antenna.
Posted on Jan 07, 2009
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
I have a hitachi 42hds52 tv; i have my cable box connected to it by both hdmi and coax cable. the coax is fine, but the hdmi is not working
Try the anothe HDMI input or cable or try HDMI from another source (DVD) you could also try component in(Ry,Gy and By) to see if that works.you need first to determine if it's a cable box, cable or TV issue.
Oct 11, 2009 | Hitachi 61SWX10B 61" Rear Projection...
HDMI and Component Outputs do not work simultaneously
try using a digatal out cable instead of rca cables this should solve the problem!
Nov 06, 2008 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
HDMI module
acess the service menu (power off then press mute 1-8-2-power) you should have a service bookfor your setting you might have the hdmi off.
Aug 16, 2007 | Samsung HC-P4752W 47" Rear Projection...
LG 30FS1D TV Logo
Muntejaya Ginting
Muntejaya Ginting
Ekse
