Zvue ZV002 Digital Media Player Logo
Posted on Apr 12, 2011
Missing a card, how do i get one? and what software do i download to make it work. How do i get music and videos on here?
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1423
Points
Zvue uses a standard SD memory card (I think there may be a 2 Gig upper limit). Mine came with a 1 Gig SD card and I can use the one from my digital camera as a spare. I use an HP card reader plugged into my PC and just drag and drop files as needed onto the SD card. Then put the card into the Zvue.
To convert the videos download "Free Video Converter" and use the following settings: Output format - Avi, Codec MPEG-4, Size - 240 x 176, Fps - 15, Bitrate - 4880. Choose Rescan from the Options menu, and then relax and enjoy the music.
2answers
Can i transfer my deezer music playlist to my sd card on my tablet and how to do this.thanks
You can do that! Here's a simple guide:
Download Deezer Music to SD Card on Android
Deezer offers different options for users to listen to music. When you sign up for Deezer Free, you can browse 90 million songs with the Deezer music app on your device, but you cannot enjoy offline Deezer. If you're a Deezer Student, Deezer Premium, Deezer Family, Deezer HiFi, or Deezer Family HiFi user, you can download your favorite content to listen to offline. As only Android devices support SD card, you can download your favorite tracks from Deezer to an SD card on an Android device.
Step 1. Open the Deezer music app on your Android device and locate the Home screen.
Step 2. Go to Settings > Other > Storage and select the SD card to save the downloaded Deezer songs.
Step 3. Press OK to confirm your settings and go back to your music library in Deezer.
Step 4. Select your favorite tracks, albums, or playlists and tap Download to download your liked content to the SD card.
How to Transfer Songs from Deezer to SD Card on Any Device
In fact, you are only allowed to download songs from Deezer to SD card on those devices which has an SD card slot. Otherwise, those downloaded Deezer music tracks are streaming content and cache files that are not playable on other devices without the Deezer music app. And once stopping subscribing to Deezer, you cannot continue to enjoy those downloaded songs.
To break those limits, we'd suggest that you use a Deezer music downloader to save Deezer songs to an SD card. Here you cannot miss this tool called Tunelf Deezer Music Converter . It is specially designed for all Deezer users and can download tracks, albums, audiobooks, playlists, and podcasts from Deezer. As it supports six popular audio formats, you can choose to save Deezer music to MP3 and then transfer songs from Deezer to your SD card.
Step 1 Import Deezer Music Tracks to Tunelf
If you have the Deezer music app installed on your computer, then you only need to launch Tunelf Deezer Music Converter first. And go to Favorites and select Music to view all of your favorite tracks, albums, or playlists in Deezer. After finding tracks you want to download, copy the music link and paste it into the search on the converter.
Step 2 Set the Output Format for Deezer Music
Importing Deezer music tracks to the converter is followed by the settings of the audio parameters. Click the menu bar and select the Preferences option from the drop-down menu. There will pop up a window where you need to set MP3 as the output format and adjust the bit rate, sample rate, and channel. Then click OK to save the settings.
Step 3 Download Tracks from Deezer to MP3
To make Tunelf software work, click on the Convert button at the bottom right of the corner. Wait for a while, and Tunelf Deetrack Music Converter will download and export Deezer songs to the default folder. Or you can change the storage folder in advance. By clicking the Converted icon, you can view the converted music in the history list.
Step 4 Transfer Songs from Deezer to SD Card
Now you need to connect your SD card to the computer and transfer those Deezer songs downloaded by Tunelf software to the SD card. All the limitations from Deezer music have been removed by Tunelf software. Then all the music can be played from a number of music players or devices from your SD card.
Serial#4585680
Serif: Web design, photo editing and DTP software
www.serif.com/
WebPlusThe leading independent publisher of award-winning, great value software. Download our web design, photo editing, desktop publishing and graphics ... every pupil to create professional graphics, video and multimedia in every subject.Missing: serial ‎4585680
Music-, Video-, Graphic & Photo Software from the market ...
www.magix.com/
MagixMultimedia software for editing and creating photos, videos and music. ... The perfect desktop publishing program for creating your own logos, business cards, ... Image editing and graphic design in a single program: Give your photos a special ...Missing: serial ‎4585680
Flexi layouts 2 full crack serial - בית ספר לכדורגל מכבי תל אביב
www.golball.co.il/flexi-layouts-2-full-crack-serial/
Upgrade keygen patch. boost and visual design multimedia software. ... Http: senderserial, full movie layout cut graphics publishing, Full color digital graphics ...
5helpful
2answers
Photos on two separate memory cards are "read error" seems to be the pictures in the middle sections of the memory card. They won't show up either when tried to download onto computer. I...
you can try asoftech photo recovery software. You can see
http://www.asoftech.com/apr/
It tells the steps how to perform photo recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
17helpful
2answers
I have music down loaded onto my SD card however when I try to play music phone says "Not Supported" How can I get the music to play?
Dear, please note that if you download a music then please do conferm that is will have to be fully downloaded upto its estimated full kb.
ex-if you download a song of 4023Kb, then your song will not be supported unless and untill your download is full.
if it is not downloaded fully then it will not work.
the same things happens with a software, video, themes, games.
4helpful
3answers
I just purchased a new HTC Inspire 4G cell phone from AT&T. I downloaded the current version of HTC Sync(3.0.5511) onto my PC so I can transfer music videos & photos from my PC to my...
There might be something missing with the drivers on your computer. You should try first reinstalling the HTC Sync software. If that does not work then try searching for a "driver" for your phone online. I have seen in forums that people have had a hard time finding the necessary driver, but maybe soon HTC will have an updated one available.
Hopefully just reinstalling the program will work though.
I wish you the best of luck and thanks for using FixYa!
How do I download music or videos into my SanDisk memory card?Is it possible to download music into the memory card when its already inside my unsupported sciphone?
All right, the following section will show you the best way to help you with the download and conversion.
Download:
1. Download, install and launch Video Download Studio from http://www.downloadvideos-convert.com/download-videos-music.
2. Click” add URL” button to paste the URL of the video you want to download. ( or you can play the video on dailymotion and click “auto capture”, Video Download Studio will automatically capture and download the video for you.)
3. Download details will showed on the working window.
Convert:
1. Click” convert” button on the top, you will switch to convert interface.
2. Click ”add” button to load your videos to Video Download Studio
3. Click” profile” drop-down list to select MP4 format.
4. Click” convert” button on the bottom, you will get MP4 format video in seconds.
As you can see, these simplest steps enable you to convert video. Join in and do it yourself, you will get a lot of fun.get it from http://www.downloadvideos-convert.com/download-videos-music
2answers
Do I install any software to start my 30gb video iPod?
Yeah. Go to apple.com- click ipod plus itunes, and click download itunes. And its totally free to download it. Then you have to buy a card at the store, scratch off the silver part, go to itunes store, click redeem, enter in the code that you scratched off, and you are set to buy music, videos, podcasts, etc.
ps:if you run out of money on your card and you cant buy another one yet, or you dont have a card yet, you can make purchases thru a credit or debit card (which is why it asks for credit or debit card info in the beggining)
2answers
Downloading videos to Zvue 250
It came with converter software for video transfer - if you lost the CD, go to the manufacturer's website
Get pictures and video off phone to the computer
Preparation ? if an external Micro SD external memory card is to be used as the desired music/video/picture repository on the W755, install the card in the W755 behind the battery. Then go to SETTINGS & TOOLS ? MEMORY ? CARD MEMORY ? FORMAT and format the new card. Caution: reformatting the card will wipe out all contents on the SD card. Download/install free Motorolla Handset USB Driver Installer onto the PC (execute ?.msi? file). Download/install free VCast/Rhapsody software (no need to actually sign in or use the proprietary Rhapsody service). Start the VCast/Rhapsody software. Turn on cell phone (works with W755 and may work with other Verizon ?music phones? such as LG Chocolate, but the latter was not tested). Connect phone to PC ? connect USB cable to PC?s USB port first, then connect USB cable to phone . Be patient, it may take a minute to fully ?connect? in the phone?s display. Go to ?Sources? section of VCast/Rhapsody GUI screen ? the phone will register as a directory title using a name roughly like ?VCast xxx.? Windows Explorer will also show a ?VCast? drive/directory device. Files can be selected and dragged to and from source and target directories. At this point various options exist regarding music, picture, video management: 1.) The VCast/Rhapody software can be used to manage music, picture, and videos between the PC and phone. Again, no need to use the VCast service, just the software offline. 2.) Alternatively, other music management software such as Media Monkey (a personal favorite) can be used to move music, create playlists, etc. ? NOTE: Leave VCast/Rhapsody software running in the background as a means to ?connect.? It is best to start VCast, then plug in phone, then start other media management software so that the media management software will benefit from the connection (usually with a directory name using some variation of ?VCast.? Then use the alternative media management software as usual. Please note, this is a generalization based on success using basic software like Media Monkey, for example.
Blackberry pearl 8100 and setup or work around to get jabra BT3030 to play music
I have a Palm 700w and just purchase the Jabra BT3030 and although the Bluetooth works with phone functions I cannot get the Jabra BT3030 to work with music functions. Is there a quick fix for this I am missing?
Top Zvue Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Zvue Audio Player and Recorder Expert? Answer questions, earn points and help others
