Question about Hotpoint Microwave Ovens
I need a User manual for Hotpoint 1000, 9926 Washer Dryer
Posted by cmoore911 on
ZJ Limited
  • 17,970 Answers
Check in this link to download the User Manual for Hotpoint 9926 Washer/Dryer
Hope this helps (remmeber to rate this answer).
Posted on Apr 12, 2011
Hot point tumble dryer has no power, fuse in plug already checked
All dryers have one or two internal high limit thermostats. They look like this.
Hotpoint Dryer Thermostat Parts
Apr 05, 2018 | In Microwave Ovens
How do I get a manual for a Hotpoint over-the-stove microwave?
Hotpoint is part of the GE company. Manuals can be printed off GE's site in the appliance customer support section.
https://www.geapplianceparts.com/store/
Feb 26, 2015 | GE Hotpoint Over-the-Range Microwave
Lost manual how do I self clean oven sy86p
.User manual can be found here at this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Cooking/SY86P_19504580000.pdf
It's a PDF File so you will need a PDF Reader like Adobe and it can be found here if you do not have one.
http://www.adobe.com/pdf/
Jun 12, 2011 | Microwave Ovens
Need hook up diargam for 240 volt 30 amp washer dryer residential xyo-gnd recepticals.now for free .like your web site said. or i will presume this is just a scam trying to lure people in for some...
Hi Watsonelecco!
No scams here... most of us on FixYa are like me.... we enjoy helping people out with their everyday problems. I work nights and do this as a hobby... I used to teach advanced electronics and Radar for the US Navy.
It is difficult for me to give you a diagram for "xyo-gnd" since the term is not familiar to me, even though I worked as an industrial field service engineer. My guess is that you need to connect your washer/dryer to your electrical outlet.
First thing.... I need to know where you are located, and what type of power service you have coming into your home. Most US homes are wired for 115 Volts and require a separate input for 230 volt appliances. Most European, Australian, and Asian homes are wired for 230 volts and connecting your washer/dryer will be simpler, but still require some work.
The first thing we will need to know is how the power comes into your home and how it is distributed. Look at your circuit breaker panel. You will have a mains coming in that feeds a 2 pole "main" breaker- it will be rated at between 100 and 300 AMPS in most homes.
Next... the other breakers in the panel.... how many are "2 pole" breakers (what looks like 2 switches connected together) and how many are single pole? Only a 2 pole breaker can supply power for your washer/dryer.
Now, you need to determine which of the two pole breakers are rated high enough for 30 amp service. If none say 30 amps or higher, you will need to install a new breaker and run a 10/3 AWG type UF cable to where you are installing the washer/dryer. Find a recepticle that matches your washer/dryer plugs, and install it with the black wire to the brass lug, the white wire to the silver one, and the green wire to the green lug.
Once you have the wiring done, you will be good to go!
If you already have a dual breaker rated at 30 amps supplying an outlet where you are installing the washer/dryer, match up the plugs/outlets the same way... black wire to brass, white to silver, green to ground. You may have to purchase either the correct outlet, or (more likely) the correct plug, since most units do not ship with power cords.
Apr 07, 2011 | Microwave Ovens
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
I bought a house that does not have any user manuals for the appliances. Do you know where I can get a Hotpoint Microwave, Model # RVM120G001 manual?
You can download GE owner's manuals and installation instructions here.
Jul 07, 2010 | Hotpoint Microwave Ovens
Hotpoint Microwave - won't stop spinning/buttons seem to do nothi
if i understand, u say it is intermittent right? control pad get wet? it is definitely not mag, diode, cap.
Aug 19, 2009 | GE Microwave Ovens
Microwave Ovens Logo
100 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Sheldon Dedek
robert
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
