There is not a particular fuse for the radio that I have found. It seems that the Jaguar radio is specifically set to power the antenna. The installer should tell you what they did with the wire. If you told them the antenna was broken, or if they couldn't get it working, my bet is that they left the yellow, or blue antenna wire unhooked during installation. If you have a good antenna, and you have confirmed it, then the antenna should work when the radio is activated. That is the only solution other than the radio having an malfunction. You can check the 10 amp fuse on the back of the radio, but my bet is the antenna wire.
Thanks.
