After doing some research, I found that you had an Intel motherboard and used a website called
www.crucial.com (Crucial is a brand of memory and have some useful tools on their website) These are the specs that came up. You can view the same information at this web address
http://www.crucial.com/store/listparts.aspx?model=WS440BX
It also shows the price of the upgrade! Hope you find what you are looking for!
- 168-pin DIMM Banking: 3 (3 banks of 1)
- Chipset: Intel 440BX
- Error Detection Support: ECC and non-ECC
- Graphics Support: AGP 2X
- Max Component Density: 128Mb
- Max Unbuffered SDR SDRAM: 384MB
- Module Types Supported: Unbuffered only
- SDR SDRAM Frequencies: PC66 and PC100
- Supported DRAM Types: SDR SDRAM only
- USB Support: 1.x Compliant
Q: Will my system recognize the maximum upgrade?
A: Possibly
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at
http://www.crucial.com/kb/answer.aspx?qid=4251.
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: SDRAM memory with support for SDRAM, PC133 speeds.
Because SDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible SDR speeds listed below.
Q: How much memory can my computer handle?
A: 384MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: No.
Your system does not support ECC. Because ECC and non-ECC modules should not be mixed within a system, install the same type of modules that are already in your system.
