Question about Mercury Computers & Internet
Change boot setup settings of the motherboard Thx
Posted by doheskor on
Brian Sullivan
  • Mercury Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Posted on Apr 12, 2011
Cmos checksum erroe defaults loaded
press del to enter setup.then choose default bios setup. then save and exit.pc will restart.
Nov 17, 2011 | Gigabyte GA-945GCMX-S2 Motherboard
Can't boot from sata CD drive to set up windows xp
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the settings to failsafe or optimised defaults) this will change the first boot device to floppy
hope this helps
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
Coms setting wrong plz detail rightbios seting in all
hope this helps
Jan 26, 2011 | Mercury P4VM800M7 Motherboard
Can't boot from USB on motherboard "ASUS p5s-mx se". No issue on BIOS Setup menu !
Start and pres Del /F 2 /F10 for Setup bios .Change the boot sequence.
Usb drive 1st
Hard disk 2nd
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Phoenix BIOS setup and help
And make a boot-able pen drive.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope it helps.
Jan 19, 2011 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
I have a8v-vm motherboard...my ad dvd writer was not working.so i purchased new sata dvd rom but now problm is thai i cant boot from it or instal xp buy this......what i do now..what is the setting in...
Restart your computer.
Press <DEL> to enter BIOS SETUP.
Look for "Boot" options, and change the "Boot Order" to make the CD/DVD the _first_ boot-device.
Save/Exit from BIOS SETUP.
Boot from the CD/DVD drive.
Dec 26, 2010 | ASUS A8V-VM Motherboard
I have Intel 845 series motherboard & I want to format my PC but when I put xp cd inside & restarts & press enter the boot doesn't start now how could i format ?
You have to change the BIOS settings to boot from your CD drive. It must have been set to boot from harddisk.
To do this you have to change the primary boot device from Harddisk to CD drive. When you restart your computer press DEL or F12 or TAB or F1(any one...Depends on your BIOS see manual or try all) to bring bios. In bios go to boot device priority and set the CD drive to boot first.
Restart your computer, it will boot from CD drive and XP setup will start.
Hope this will help...cheers:)
Sep 25, 2010 | Intel 845GE Motherboard
I want to reformat my computer, my question was how to first boot my cd rom to install...
Start your computer.
When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
Save-and-exit from BIOS setup.
Insert the disk into the CD-ROM.
Your computer should boot from the disk in the CD-ROM.
Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
How i can boot from cd
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
Mar 19, 2010 | ASUS P4B266-C (P4B266-C WA) Motherboard
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
I changed RAM settings in BIOS, now I can't boot
try jumpers ok move to 2 and 3 for few sec then back on 1 and 2 pins on mobo ok thx nick take ram out do one at time defult to auto in bios thx nick
Feb 06, 2008 | ASUS P4S533-MX Motherboard
Computers & Internet Logo
236 people viewed this question
Top Mercury Computers & Internet Experts
Thomas F. Schneider
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Gustavo Ortiz
Gustavo Ortiz
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
