Question about Bosch Dishwashers
I have a bosch dishwasher model number SGS0902GB/05. I use tablets instead of detergent. I put the tablet in the Dispenser and close the lid, noproblem. I then set the programme and shut the door, I usually set the programme to delay start so that it washes dishes in the small hours when all are in bed, however, when I have set the programme and close the door within a minute the dispenser assembly opens and the tablet falls into the dishwasher, I then try and put the tablet back in the dispenser and close the lid however the lid will not close. I am thinking a replacement dispenser assembly however I eagerly await your advice. We have had the washer for 10 years now with no problems at all. It has been a great washer. Many thanks Andrew
  • 3 more comments
  • andrewfraser Apr 12, 2011
    Hi BE and thanks for the advice, you are so right. I did exactly as you said, switched the machine of and closed the dispenser and it stayed shut. I then did the same with the dishwasher on and set to delay start and the dispenser opened, so it seems it is not the dispenser...
    Not sure of you got my comment. But I did what you said and you are right, with the power off the dispenser stays closed. With the power on the dispenser opened as you say.. would appreciate your thoughts..
    thanks
    andrew
  • andrewfraser Apr 13, 2011
    HI BE, once again thanks. I do have these tools. So will await your advioce on what to do next. Thanks for your patience and your expertise.
    Andrew
  • andrewfraser Apr 14, 2011
    I have inserted the probes and powered on, set it to delay and I am getting a reading of 237 V, so its not 0 as you say...
    I did the resistnace test on the actuator and that read 1.6 so that was ok..
    Andrew
  • andrewfraser Apr 19, 2011
    Sorry BE, been a hectic time to be honest. Thanks soooo much for your advice it was perfect and extremely accurate. We have decided to place the tablet in the cutlery basket and use the washer this way until it eventually dies. We have had it 10 years so I think it has lasted?
    any recommendations on what diwhwasher to buy next? I am convinced we should stick with a Bosch as it has been quality.
    Would value your thoughts? that said I will buy a control panel if you think the washer still has some legs?
    Thanks BE
    Andrew
    President:
  • 1,140 Answers
Hello Andrew,
I'm more than happy to give step-by-step instructions for replacing the detergent dispenser, however it's not cheap (about £50) and it probably doesn't need to be replaced. Some of the smaller components for the dispenser are available separately, so it would be better to work out what's wrong with it, before replacing any parts - or the entire unit.
The dispenser may be receiving an erroneous signal from the controller to open when the dishwasher is in delay start mode. To check this, switch the power off, insert a tablet in the dispenser, and slide the door closed. Make sure it clicks shut fully (push on the arrow on the door)and then wait for a few minutes to see whether it opens.
If the tablet will stay in the dispenser with the power off, there is nothing wrong with the dispenser. If it opens with the power off, you may just need a new dispenser door or a spring. Please try this simple test, then get back to me for further assistance.
Regards,
BElectric
Posted on Apr 12, 2011
  • 15 more comments
  • DILLIGAF
    DILLIGAF Apr 12, 2011
    Thanks for getting back to me - you may be lucky and find it's just the switch in the dispenser that operates the release mechanism. These are cheap and simple to replace. Unfortunately, if it's not the switch, it's a fault with the controller.
    You're going to need 2 things to determine where the fault is - a multi-meter and a Torx T20 screwdriver or screwdriver bit. The first part is just a visual inspection of the mechanism with the outer door panel removed.
    Do you have or can you borrow the tools?
  • DILLIGAF
    Yes, I received your reply - my thoughts are above ^.
    Sorry, the split asker/expert messaging system on these pages can be a little confusing.
  • DILLIGAF
    You seem to be having some difficulty locating my messages. I'm just posting this to generate a email notification for you in the hope that you will search this page again and find my comments!
  • DILLIGAF
    One more try - hopefully you'll locate these messages eventually . . .
  • DILLIGAF
    DILLIGAF Apr 13, 2011
    Hi Andrew,
    Glad you found my messages - sorry for the delay. I've only just switched on today.
    First thing to do is remove the outer door panel. Open the door and fold it all the way down, then undo the 6 T20 screws on the sides of the inner door panel - 3 on each side. Leave the 4 along the top of the door.
    Please switch the power off while dis-assembling the washer.
    Now close the door, and grip the outer door panel on both sides near the bottom of the door and pull. As the panel comes away from the door, allow it to drop slightly so the small metal tabs at the top can slide out from behind the fascia panel. The outer door panel should now be totally removed from the washer, so put it somewhere safe until you need to re-attach it.
    Don't worry if 2 chunky plastic clips fall out - they simply push back on to the brackets on the door when you re-attach the panel - I'll show you where they go a bit further down . . .
    You should now be able to see the back of the dispenser (note the plastic door clips near the bottom).
    Close-up of the back of the dispenser . . .
    OK. The red box is the solenoid/switch which operates both the detergent drawer opening mechanism and the rinse-aid release valve (The red wires are for the rinse aid level sensor). The piston on the switch (ringed in red) should be fully retracted as shown when the washer is idle.
    Now to test. Put a tablet in the dispenser, close the door and switch the power on again. Set the washer to a delay start program, then observe what the piston on the switch while waiting for the tablet to be released. The piston projects about 5-7mm (1/4 inch) when powered from the controller, but it happens very quickly so keep watching!
    Try this first, then get back to me. The next part is a voltage test with the yellow wires removed from the dispenser. I'll start writing the instructions for this separately and post back with them shortly.
    As soon as I receive your reply, I'll get back to you. I wont leave you hanging with a disassembled washer ;)
    Regards,
    BElectric
  • DILLIGAF
    Hi Andrew,
    Don't know whether you've read my previous message yet, but having thought about it a little bit more, I suspect a fault in the control module - most likely a failed relay for the dispenser actuator/switch. Once you've removed the door panel , you may as well go straight to electrical testing . . .
    1. Disconnect the washer from the power supply
    2. Pull the white block connector with the two yellow wires downwards to disconnect it from the actuator on the dispenser.
    3. Test the resistance of the actuator across the two pins which were exposed when you removed the block connector. If the actuator is good, the reading will be between 0.5 to 2.5 ohms. A little higher isn't a problem
    Finally, test for voltage to the block connector you removed from the actuator . . .
    4. Set the multi-meter for AC volts in a range greater than 200v.
    5. Insert the red and black probes of the multimeter into the two spade connectors inside the white block connector.
    If the probe pins are small enough, they will push into the spade connectors. If not, you will need to find some way of holding the probes in place while making sure they maintain contact with the spades inside. I don't advise holding them in place manually as the supply to the actuator is 220-240v.
    6. Power on and set the washer for a wash cycle with a delayed start of an hour or more
    7. Observe the voltage reading on the meter for several minutes.
    You should be getting a constant reading of 0v. If there is a voltage here immediately or within a few minutes, there is a fault in the control module. This circuit should not be powered until the point in the wash cycle where the tablet is released.
    Please test as above, then let me know the results and we'll go from there . . .
  • DILLIGAF
    Hoping you've managaed to find these messages, rather inconveniently 'hidden' down here.
  • DILLIGAF
    DILLIGAF Apr 14, 2011
    Haven't heard back from you - hoping you've found my messages . . .
    Hi BE
    Wopndering if you are getting my messages now.. I did the resistance test on the actuatir and that was fine, the reading was 1.6.
    I plugged in the probes and set the machine to delay and there was an immediate reading of 237v, you mention it should really read 0, so there is a fault there I believe?
    Hope your getting this
    thanks
    Andrew
  • DILLIGAF
    It's OK. I was in the process of replying to you. The good news is you found the problem. The bad news is, it's the control module rather than the dispenser actuator. There is a relay on the control module for the actuator - this appears to have failed in the closed position meaning there is constant power to the actuator when the washer is powered.
    There are 2 options here (unless you can repair PCBs at component level?) - replace the control module, or put the tablet in the cutlery basket. The control module can be self-installed and will cost about £100. I can provide supplier details for a new control module, part number and instructions for installation.
    Please let me know where you want to go from here.
    Thanks BE,
    you have been brilliant. In your opinion. Given that we have had the dishwasher for 10 years now without failure of any kind is it worth getting a new control module or is this the beginning of the end of the washer, cause Ime thinking if it is, I will just use the washer until it dies and put the tablet in the cutlery basket?
    Andrew
    PS, when I put the door back on can you tell me where these two big bits of plastic go that fell out when I took the door off?
    Thanks
    Andrew
  • DILLIGAF
    The door clips push on to the protruding metal brackets near the bottom of the door. Put these on before re-attaching the door panel.
    To re-attach the door panel, grip it on both sides about a third of the way up and slide the tabs at the top into the slots behind the fascia panel. Once the tabs are correctly located in the slots, push the bottom of the door in over the plastic clips. You may need to flex the panel slightly to get the flange on the back of the door panel over the clips.
    After that, make sure the panel is fully pushed up, then open the door slowly and put the screws back in. It's best to start with the screws near the bottom of the door and squeeze the outer and inner door panels together with one hand while tightening the screw with the other.
    I will get back to you with advice on the controller in a few minutes . . .
  • DILLIGAF
    Sorry for the delay. I thought I'd get you the current price on the control module just in case. Original part number was 269978 but this has been replaced with 484322. Cheapest is direct from Bosch at £194.99. Hmm, at least that includes delivery . . .!
    Very few other suppliers for this part now anyway and some of them are over £250. Unfortunately, the cost seems to increase, the older the washer gets.
    At that price on a 10 year old washer, I wouldn't even consider it. I bought a new Siemens for £320 a few weeks back. Putting the tablet in the cutlery basket works, but it's not ideal. You need to check it's fully dissolved after each wash and, if not, vary the position of the tablet in the basket.
    The drawback to this is the tablet is released at different time intervals for different wash cycles. On a quick wash, it's released a couple of minutes after the cycle starts. On a long/heavy soil wash, there is a pre-rinse before the tablet is released.
    If you decide to replace the appliance, I'd recommend www.appliancedeals.co.uk (I have no affiliation). I've ordered numerous appliances from here for customers, they deliver next day and I've never had an issue with them. They handle appliance sales for Next, Sainsbury's, Boots and quite a few others, but the prices buying direct are significantly less.
  • DILLIGAF
    Did you get the door back on OK?
  • DILLIGAF
    Again, I'm wondering whether you got my messages or if you now have a stray ornamental dishwasher door panel adorning your kitchen . . . ?
  • DILLIGAF
    DILLIGAF Apr 19, 2011
    No problem. I was just a little concerned that you hadn't received my messages and had a loose dishwasher door panel decorating your kitchen.
    I don't advise spending £200 on a 10 year old washer. It's impssible to determine how much longer your washer will go on for as there are numerous factors to consider, but 10 years is a good average for a Bosch. Life expectancy depends on how often it's used, water hardness, how well it's maintained - and an element of luck.
    If the tablet is fully dissolving in the cutlery basket and your dishes are coming out clean, there is no need to spend money repairing the washer or to replace it until another major component fails and/or the total repair cost exceeds the cost of replacing the entire washer.
    The appliance spares industry is little more than racketeering, in my opinion. Small components which could be easily be sold separately are bundled as complete assemblies, instructions for simple repairs are witheld from consumers and schematics for control modules are rarely available, even to service technicians.
    The cost of replacement parts bears little relation to the cost of production and the prices are set to 'encourage' consumers to replace the appliance as often as possible. If it's out of warranty and you can't self-repair, one major component with labour charges is often close to the cost of replacing the appliance. Two major components and it's generally cheaper to replace. If you tried to build your washer from scratch, buying all the individual parts (assuming they were available), it would probably cost around £2000 to do so.
    If there's a way to beat the system, do it. When you do decide to replace though, I would definitely recommend buying another Bosch. They are more expensive to repair than other major brands, but the build quality and quality of components is generally better, in my experience. Other brands made by Bosch group e.g. Siemens and NEFF use identical components and only really differ in appearance, but you pay a little more for the name with these.
    I do recommend ApplianceDeals, but you have the luxury of still having a usable washer, so I'd simply advise you to keep an eye out for a good deal on a Bosch and buy when you see one.
    The last advice I would give on buying a new dishwasher is not to waste money buying a more expensive one with features you'll hardly ever (or never) use. If you run your dishwasher once a day using only one or two different wash cycles, you only need a dishwasher that has these features and, in your case, a delay start. The more features there are, the more things can go wrong and the more expensive they are likely to be to maintain.
    If you're so inclined, you can also strip the old washer of known working components and sell them on Ebay. People are more than willing to take a chance on paying £20-30 for a used circulation pump motor, water heater, controller, etc. It's not surprising when you compare this to the cost of new components. You can recoup 30-40% (sometimes more) of the cost of a replacement dishwasher this way and often you get a few spares for the new machine. Much 'greener' as well!
    Hope this helps. If I can be of further assistance, please let me know.
    Regards,
    BElectric
6ya staff
SOURCE:
Dishwasher tablet does not dissolve so crockery not clean
Are you using a rapid wash program, ie 30 minutes total?
if you are, put the tablet in the cutlery basket, not the soap dispenser. The wash time is very short on the 30 min program, so putting it in the cutlery basket gives it more time to dissolve.
Other problems might be problem with water level, (should be just above the filter but below the lip of the wash tank), pump not working or the spray arms not turning - (check the angled jet at the very end of the spray arm for blockage by food particles).
Feb 04, 2018 | Dishwashers
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
The compartment where the dishwasher tablet goes in doesn't always close.
It might be helpful to know the model number of the dishwasher.
It is likely the detergent dispenser compartment lid has a faulty latch. This gets fixed by replacing the whole dispenser.
May 16, 2011 | Miele Dishwashers
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Mar 05, 2011 | Whirlpool DU840CWD Dishwasher
Detergent tablet does not dissolve
If you are putting the tablet into the dispenser and closing the lid the problem is that the lid is not opening as it should. No problem actually, just toss the tab into the floor of the dishwasher. it will work just as well. Joe
4 thumbs up. ty
Oct 27, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Should the detergent dispenser door be open once the cycle is done? I always saw it as open so I knew the detergent had been emptied, but now when I open the dishwasher after completion of all cycles the...
Hello, Yes the door should be open at end of wash,either the dispenser is faulty or the p.c.b. If you dont want to go to the exspense of new dispenser etc.Try putting tablet ( I presume you are using tablets ) in the cutlery basket.If you are using powder then it will have to be repaired.
Hope this helps.
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Dishwashers Logo
1,104 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
