SOURCE: I have a WorkCentre 5225 and it is telling me that
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
SOURCE: i have xerox works center pro photo copier model
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
SOURCE: Hello. We have 2 Pcs of Xerox Copier
Try removing the fuser and re installing it.
If that doesnt work then the fuser is bad.
