Sharp 25N-M100 25" TV Logo
Question about Sharp 25N-M100 25" TV
I have a cable running from my set top box to another tv. Although i have a good picture there is not enough volume on the sound. It has worked perfectly well until I had to dismantle everything . I have a video recorder and a DVD attached. they are both working perfectly well.
Posted by elke2702 on
Anonymous
    New Friend:
    Problem Solver:
  • 4 Answers
This is not how you explain your problems to others. It should be precise. In this case, you could have said that you connected the cable between the RF out put of set-top box and RF input TV. Or Audio/video output of set-top box to Audio/video input of the TV. Also you did not mention, to which port you had connected the Vedeo recorder and DVD which are working good. Now, it may the volume level of the set-top box at low level which you can try to increase by using the remote control
If you could not sort out the problem explain how you had 'dismantled everything'
Posted on Apr 12, 2011
I have a onkya TX NR509 I have been struggling to set this up properly. I can't get the volume to work, although when I check the speakers in the set up menu the speakers work fine. I have A Xbox, set...
Is the X box powered on when you don't get sound? Hdmi cables are not all alike. Some cables don't pass audio. Make sure you have the correct HDMI cable
3answers
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
1helpful
Luxor 40 LCD TV no sound
First, check the volume and mute settings, especially if there is another person in the house who may have changed them, and check another channel or input to ensure the signal source is not the problem. Next, verify that the sound is set to use the internal speakers, or that the external sound system is set to the input from the TV (some TVs with external sound output connections can be set to disable the internal speakers so they don't interfere with the external sound).
If you have no sound on any input, muting is off, and the volume indicator acts correctly, then the audio circuit on the main board is defective, or the audio power supply needs to be repaired. If your TV has a sound output connection that you have not connected, try connecting it to an external sound system and setting the TV sound to go to the external sound system. If it works, then you have narrowed the problem to the sound power amp in the TV, or to a bad power supply (some TV models have a power output specifically for the audio amplifier, although that is not common).
Most of the time, power supply failures in LCD TVs are the result of burned-out electrolytic capacitors. These are usually identifiable by the domed-up top of the capacitor, as pictured here. Note the flat tops on the good capacitors nearby. If you see these on the power supply board (the cable from the power board connector goes to the power supply), have them replaced with Panasonic FR-series capacitors; these usually have the best combination of price, power handling capacity and longevity.
3helpful
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
1helpful
Suddenly my yamaha Rx-v2300 only works to provide sound at nearly full volume to get any sound at all. This then comes with a background buzz. This only occurs while getting cable TV signal, using other...
I'm assuming you have a cable converter box (set-top box) that you have hooked to your receiver. Check the box volume using the cable company's remote control. These boxes frequently have variable audio output, and if you turn the volume down on the box you'll have the symptom you're describing. When you press the volume up or down buttons on the remote, you'll usually see a volume bar on the TV screen. As you raise the volume, there may be a point marked by an arrow, which is where you should set the volume. On some boxes, when you get to a certain level the words "best stereo" appear, and that's where to set it. If your box doesn't have some indication like this just leave the volume set 3/4 or full up. Then the volume on the receiver should function properly with the cable TV input.
I have a Quasar TV that has worked perfectly fine until the other day. Picture is fine, but no sound. The speaker volume is on.
Check all your channels. If you are getting sound on some channels but not others it is a good possibility that your SAP setting is turned on. Simply go into your audio menu and disable the SAP. Not sure about your model tv but some Tv sets had a switch on the back to disable the speakers and some have a setting in the menu to disable the speakers. If you have a digital cable box hooked to the tv it is possible the cable box volume is turned all the way down which will override your tv volume. Check these options and hopefully one of them works for you.
1helpful
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to have picture,somethings on the screen,words mean ur tv still works.
1helpful
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
47helpful
5answers
Vizio speakers make a buzzing noise
It's not the speakers. I usually hear of this problem when hooked up to an HD cable box. You can adjust the volume on the cable box and also on the TV. I'll bet you don't have this problem when watching a DVD.
If the problem is what I think it is, your HD Cable box is set at a really low volume while your TV is set to a rather high volume. Try setting the TV volume to around one-third, then set the volume on the cable box until it's as loud as you'd ever want to hear it. With the TV at such a high volume, you're actually amplifying any stray electronic signals that the wires might be picking up, and the above solution will fix that.
Good Luck.
SAP - I can't get my new TV out of Mono and into stereo.
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
