My camera symptoms are identical to what been descirbed in other posts, I was taking snaps and then when I turned it off and then back on again it stopped responding, I though battery might be out of juice (but earlier battery was showing 100mins left), when I came back home I charged the battery, put it back in the camera, the red light near memory slot blinked, but I wasn't able to turn the camera back on, shutter or button it's not working anymore, nothing happened physically to camera.
SOURCE: Battery Life Very Low
Might be the wrong rechargable batteries? And don't even try to use regular AAs The camera shuts itself off. You have to use rechargables.
SOURCE: Sony DSC W70 lens stuck!
This is what I found out on this and how I fixed it. This is all relative to my camera. What I found out was the view finder has a small detent which rides in a groove. When droped or bumped it falls out of the groove. To fix this I had to remove the lens assembly and realign the view finder guide. I was a fairly simple procedure.
SOURCE: Camera does not turn on.
I had a similar problem and it was a result of the battery not charging correctly. I bought the travel battery charger and an additional battery from amazon to see if maybe the battery was just old or just not charging. I figured out that the internal camera charging mechanism just wasn't working b/c the battery charged fine with the travel charger. I like the travel charger better and with two batteries I can charge one while the other is in use. I haven't had a problem since. When you buy the new battery you still have to charge it before it's first use. I hope this works for you as it did for me.
SOURCE: sony cybershot 4.1 DSC-P43
Hi
I bought a new 1MB memory card for this camera and was dismayed to find that the screen went completely blank - I couldn't do anything!!!! It was my sons graduation so had to buy another camera!
But, have just resolved this issue by pressing the bottom right-hand side of the screen with a rubber topped pencil - it works!!!!
This camera may be old and chunky but it still takes amazing pictures.
Hope it works for you too.
SOURCE: Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
Same here. Red light blinks 2 times long, 2 times short.
I have NO idea where I can take this to get it fixed and I know it is gonna be expensive
the camera is not working after the battery is charged
