Nikkai TV888D Portable 8inch DVB-T & Analogue TV intermittent on 12V
Nikkai TV888D (Maplin A13FG) Portable 8inch DVB-T and Analague TV
TV works fine on mains supply, but is intermittent when powered from a 12v (car battery) supply. When the battery is being charged with terminal voltage 13v or more, it works fine. Is there some voltage sensing circuit that has drifted out of spec?
Posted by dholburn on
5 Related Answers
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: HP D530 SFF desktop
it is depend up on the power supply connector and it will give the output according to the smps you can do one thing try with installing other fan and see is it in perfect rotation. bye
Posted on Oct 09, 2007
Mechanic688
Mechanic688
  • 204 Answers
SOURCE: 120VAC dead
There should be a small fuse on the circuit board inside the tv. Sometimes the fuse is soldered direct to the board and not in a holder. Hope this helps you,,, Mechanic
Posted on Jan 18, 2008
Anonymous
  • 7 Answers
SOURCE: digital recieving
I suspect thr system may have parcially damage please try manual tunning or fine tuning
Posted on Jan 25, 2008
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: Dual Voltage (5v / 12v) Sirius Hardwired Car Power Supply
Click here first for installation guide
Posted on Feb 11, 2008
SOURCE: Broken AC Adaptor
Check on Radio Shack maybe they got something usefull for your problem
Posted on Jun 03, 2009
I plugged in my nikkai 8inch TV to the wrong polarity ( 24 volts) can b anyone help
sure most any repair shop can replace the parts you blew out .
Nov 25, 2015 | Televison & Video
How can i change tv to dvb
Hi
On my set I just hit the input button 'TV'. By pressing the 'TV' button again causes the TV to toggle between Analogue and digital.
On my Panosonic I have buttons on the remote labelled input, with a sub selection of either AV or TV.
regards Jacko
Downunder
Aug 30, 2014 | Televison & Video
Got the Nikkai JV-TV888D had no problems at all until now...It won't tune - in and just displays 'No Signal' on the screen! Any help will be gratefully received!
Have you checked that the aerial is plugged in? Does it have an external aerial? If so is it plugged in (Socket on rear takes telescopic or external). If external have you tried aerial on another tv?
If your service is digital is it switched to Digital TV? If it's switched to analogue and you're trying to tune in it wont find signals if you're in a digital area. (or to a certain extent vice versa)
May 20, 2014 | Televison & Video
I canot get dvb back on my nikkai 8.4 tv
Check whether you have selected the correct input device from the correct input AV1 to .....
Jul 22, 2012 | Televison & Video
I have a tv digisender (Nikkai) which works fine with an analogue tv on a scart lead, but not via a scart lead with a Kenmark dtv. (Error message is no signal received) Help!
you have to select scart on the kenmark tv from the source menu as your digi receiver probably does not have an av switching voltage
May 01, 2010 | Samsung WS-32M066V 32.28 inch TV
Have a Nikkai A11HJ (Distributed by Maplin, UK)
I have a Nikkai A11HJ DVD Player with a problem, it plays disk for about 7 minutes and then stops playing and reverses back to the TV, can anyone help?
Jan 30, 2010 | Televison & Video
Polaroid TV TLU-01911CU - no TV signals via analogue input?
Tries the web.because not popular tv brand it hard tv find parts for.It not cost effective for the
manufacture to produce very much extra parts.
tries these websites.Tv Repair World.com and
Shopjimmy.com might have ur parts.
Sep 03, 2009 | Televison & Video
Nikkai 8 inch DVB-T - no teletext
Teletext and Ceefax stopped when the UK went digital.
Aug 27, 2017 | Televison & Video
DVB not working on panasonic TX26 LXD52. Can't change channel nor access any menu's, guide etc when in DVB mode. Analogue tuner and av functions working fine. Remote works fine in analogue mode with...
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Apr 30, 2008 | Panasonic Televison & Video
Recording DVB on this DVD recorder?
Have sorted this problem now, I purchased a SCART DVB TV Unit from Freecom, this did not work at first connection, but I then realised that it had to work as RGB into the SCART plug on the DVD, once I set the unit to RGB, all was fine.
I can now record Freeview on my DVD fine.
I do however have one prblem which this will not overcome, that is the addition of yet another remote control !!!
Byeeeeeee..
Nov 30, 2007 | Pioneer DVR-220 DVD Recorder
Televison & Video Logo
625 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
