SOURCE: stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
SOURCE: Poor washing and drying
I have the same problem. I have contacted warranty dept. by phone and email today. I will keep you posted.
SOURCE: I have an Ariston 640 LI dishwasher and no water
hi there Mellisa, Is the tap turned on? if it is in may be the inlet valve at fault you will need to have it checked it see if the valve is recieving the open command from the controler. let me know if this helps, regards
Gary
