How to boot into safe mode or VGA mode Sometimes while changing video cards you can get Windows into such a bad state that it refuses to boot. If something is wrong with your display drivers Windows will often be unable to start up properly. But in order to fix the problem you need to get into Windows so you can re-install or fix your display drivers. So Windows won't run but you need to use Windows to try to fix the problem. Fortunately Windows can run in "safe mode" which allows it to boot while not using your installed display drivers. Unless Windows is severely damaged, it should be able to boot in safe mode.
To get into safe mode with Windows 98 and ME press and hold the Ctrl key immediately after you turn on your computer. In other versions of Windows you need to press the F8 key. On some computers you can press and hold F8 and on others you have to press F8 at the right time which is usually just after the initial BIOS screen (see fiddling with your BIOS) has been displayed. If you can
