Question about Toshiba Sattelite® A105-S2051 PC Notebook
I have a toshiba sattelite l3oo and i have a problem with my charger. when ever i plug my charger the laptop will reboot(when starting. i can't start the computer when my charger is on. and when i'm using my laptop and the battery is low and i put the charger on, the screen turned to crash or totally black out. can anyone pls help me thank you
Posted by LioNeL_08 on
bruno504
    New Friend:
I had same problem with my Sattelite L300. Motherboard has a defect in one Proadlizer film capacitor exactly on the back of CPU, the original ref. is nec-tokin 0E907 (900uF/2.5V) or similar code. I've replaced it by 4 tantalum capacitores of 470uF/2.5V each and 2 capacitores of 220uF/2.5V, all in paralell mode in same old place of nec-tokin component.
Vote for me... :)i have a toshiba sattelite l3oo and i have a - 3_10_2012_6_45_55_pm.jpg
Posted on Mar 10, 2012
NinaE
    President:
  • 3,278 Answers
Hello.
First, with the power off, remove the battery and reinsert in the laptop.
If still a problem, to replace your A/C power adapter, go to or search for a universal charger for your Toshiba Satellite. Targus or other brands make charger for your laptop.
Hope this helps.
Posted on Apr 12, 2011
I have a toshiba sattelite l3oo and i have a problem with my charger. when ever i plug my charger the laptop will reboot(when starting. i can't start the computer when my charger is on. and when i'm using...
Vote for me... :)
May 03, 2011 | Computers & Internet
Keyboard wont work
Shut down the computer
Unplug the power cord
Take the battery out for a few minutes
Replace the battery and start the computer
Problem fixed
Plug in power cord
Dec 02, 2010 | Toshiba Sattelite A105-S2051 Notebook
My laptop is a tishiba A205 sattelite s5812 the computer will not operate with charger/adapter plugged into the computer
Seems like this is a charger issue.. Try to change the charger that you are using with your friends cahrger or a replacement charger.. If you dont have one just get one.. The problem will be fixed
Oct 14, 2010 | Toshiba Computers & Internet
Toshiba Satallite a75-s2112 laptop when plugged into a/c power, the ac power stops working, then goes to battery. If I unplug the power adapter and plug it right back in , it will start working and then go...
This is a problem with your charger, I had the problem with my toshiba Sattelite, it was either a break in the wire or a short in the brick. You need to purchase a new charger.
Dec 23, 2009 | Toshiba Satellite A75-S211 Notebook
C drive filled
It might not help but sounds to me like it updated a lot of updates. You might have to let it keep starting and rebooting till it has installed all the updates.How do you know it filled your hard drive?
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Laptop A205-S4577 won't start up
If the battery is removed, it should still start up with the charger connected. A lot of laptops develope problems with the jack where the power supply plugs in, from constantly plugging & unplugging the charger. The jack in the back of the computer is probably bad.
Jan 15, 2009 | Toshiba A205-S4577 Notebook
Toshiba sattelite a200 won't turn on
This is a common problem for toshiba laptops, unfortunatly. Usually when this happens either your laptop charger is fried, or you will need to replace the actual laptop plug inside the laptop.
Oct 31, 2008 | Toshiba Satellite A105 Notebook
Try removing the battery. It might be faulty and shorting the adapter.
Oct 31, 2008 | Toshiba Satellite A60 Notebook
Accidnetily deleated a file that has now caused my toolbar and start menu to go black and grey
Try putting the system disk (xp, 2000) in the disk drive and rebooting the system.
Apr 14, 2008 | Toshiba Sattelite A105-S2071 Notebook
Toshiba Sattelite® A105-S2051 PC Notebook Logo
3,800 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
