Fan problem is one of the most common reasons for the freezer to start
failing, this is called "frost free failure." Ice can build up on the
evaporator coils over time, and this ice builds up until it starts
blocking the fan. The fan is responsible for circulating cold air
throughout the freezer, so if it is blocked the freezer will not be able
to freeze any food. You can usually check this by removing an access
panel in the back of the freezer to inspect the coils. If ice is built
up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is
burned out or the motor isn't running, cold air can't circulate through
the freezer and everything will melt. You can normally hear the fan
motor switch on and off from time to time. Listen for it and if you
can't hear it coming on for an extended period of time, the motor may
need repair or replacement. The wires connecting to the fan may be the
problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator,
which results in the cold air being lost instead of circulating
properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your
food will thaw even though the freezer isn't malfunctioning. Always
leave some space open in the freezer and try to not store food right up
against the cooling vents.
The thermostat might have shorted out, which means the freezer can't
accurately determine how cold it is. If this is the case, the
refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just
refreeze over and over again, which could damage the lines as well as
the fan. Always check the drain and make sure no sludge is building up
in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The
more the door is opened, the more warm air is let in and cold air is
released. If the door is opened frequently, the freezer could be warming
faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
