The defrost heater or thermostat circuitry is bad,you need to test both components,also the defrost timer control if the other parts test o.k..,the defrost tstat has to be below 32 degrees or it will test bad/open,when the evaporator coil gets iced up you cannot blow cold air through a solid block of ice,(NO air flow)means no cold air throughout the unit even with the evaporator fan running
OK, it worked fine for a while and then got warm again so it wasn't just frozen. How can I test the Thermostat circuitry and the Defrost Heater? I have a multimeter and some electrical knowledge but need to know where to access these components and what the readings should be.
Many thanks!
OK, I found and tested the Defrost Thermostat and it is fine. I put the fridge into manual defrost mode but there is no power getting to the defrost heater. Could the control panel be faulty or is it the adaptive defrost control board? How do I access this board if it is?
