Question about Danby DWC283BLS Wine Cooler
My Danby wine cooler fan is making a horrendous noise - it sounds like it's trying to start up and then it gives up. I hav tried tightening the housing screws but this works for a couple of minutes and then the noise starts again.
Posted by thefefers on
ranbar
    New Friend:
Where is the noise coming from? Check the fan at the back of the upper compartment. They seem to be defective and die after about 3 years (just outside of warranty... how convenient). I'm dealing with the same issue now. (As search on the internet indicates that we're not alone!) When its making that noise, try pressing the back plate around the little fan and see if it changes the noise.
Posted on Apr 12, 2011
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Wine cooler noise
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC283BLS Wine Cooler Logo
453 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
