SOURCE: I have a single
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
