Question about Behringer Eurorack Ub802 - Ultra Low-Noise Design 8-Input 2-Bus Mixer
Where can I get a power cord for a Behringer Eurorack UB1002
Posted by phlaguer on
Mical Caterina
  • 3,400 Answers
Any Guitar Center
Posted on Apr 11, 2011
Behringer eurorack mx 1604a
36V center tapped plus 48V phantom power, this is, 18-0-18VAC plus 0-48VAC transformer, this should be the correct voltages...
Sep 20, 2013 | Behringer Music
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
I have a Behringer eurorack ub1002 mixer. how can i open it up to fit a new socket on the face of the desk. I seem to have unscrews all the screws
One has to remove all the knobs, including the faders. There are MANY screws through the panel AND all the 1/4 inch jack hardware has to be removed. Remove EVERYTHING else BEFORE removing the small screws... It is a LOT of work, although this mixer is small compared to some! Be careful to NOT scratch the circuit board as Behringer uses very small/narrow circut traces that are easily damaged. Make sure you have the EXACT same socket so it not only lines up with the holes but is the right height from the circuit board, Temporarily mount the socket along with the mating ones before soldering the pins so it is in perfect alignment to fit the hole in the panel.
Jan 25, 2011 | Behringer Xenyx 1002fx 10-input Mixer W/...
LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Dec 15, 2009 | Behringer Music
Behringer Eurorack Ub802 - Ultra Low-Noise Design 8-Input 2-Bus Mixer Logo
732 people viewed this question
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
