Rangemaster Classic 90 (Electric) Kitchen Range Logo
Penny Scott Posted on Apr 11, 2011
The gas oven on my Range Master is not burning correctly.It makes a hissing noise when it is light,and doesnt heat up as is should.I cannot get to the burner to clean it.What can I do???
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
191
Points
The electric fan oven and the gas oven is not working on my range master classic 90. I need advise --many thanks.
1helpful
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Gas oven lights but flame weak and makes hissing noise
Has the regulator been switch to Propane? this may be the problem if it was just put in service for propane.
My oven will light but flame is small and makes hissing noise like being restricted, I did replace ignitor but still the same
Hey Larry Storck, thanks for your post!
It sounds like a potential problem with your ports being clogged or your igniter is not aligned. I would seek assistance from a professional to come and properly diagnose your range. -Matt
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
I own a frigidaire es200 electric range MODEL# FEF352DWE my oven wont heat up, indicator lights are working but no heat at all in the oven yet the broiler and stove top works just find just the bottom...
Thanks for choosing FixYa and welcome to the site. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
Hi: I just installed Frigidaire gas range and have a couple questions. 1. 2 surface burners each have flame too high on only half the burner. it shoots up pretty high. How can I adjust this? 2....
Hi. There is an adjustment screw on each burner. Just make tiny adjustments until you are happy with it. Regarding the gas hiss, yes that is normal.
3 thumbs up please. Thanks, Joe
GAS NOT COMING ON.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
JGBC20BEHCT OVEN PROBLEM
can you hear a hissing sound? if your element isnt working it will need to be replaced as a saftey measure most ovens will not "pass gass" without a working element to prevent explosions, try wiggling the connnections to the element and make sure everything is tight and see if it will heat
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
