Question about Palm Zire 72 Special Edition Handheld
Good Morning, My Zire 72 does not want to turn on .. I did a reset pushing the on-off bottom + reset on back. It worked, but after shuting down the palm, it does not want to turn on again. I thought it was a battery problem so I bought a battery but the problem happened again. It seems to be a software problem more than hardware as I thought in first place .. Would you advise??
5 Suggested Answers
Anonymous
SOURCE: How to HotSync Clie' and Palm Zire
install it on another computer buy her a computer
Posted on Oct 17, 2007
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: palm Zire to itouch
Those two devices are not compatible to one another. You may get it to work by exporting the Palm desktop data into a CSV file and importing it into the program you use to sync the Itouch with.
Posted on Jun 09, 2008
Anonymous
  • 109 Answers
SOURCE: Palm Zire 72
You have a bad connection, or no connection to the digitizer. This is common when changing out batteries. Re-open the case and check the connector to the digitizer.
Posted on Jul 19, 2009
Anonymous
  • 109 Answers
SOURCE: How to insert a sim card into my Palm Zire 72
No sim card in the Zire 72. On-board memory on the motherboard only to store records not directed to or on expansion memory card.
Zire 72 battery changeout not designed to be user serviceable. Undertake at your peril (unless you are very steady handed, patient, and very very careful). The 72 is probably the most difficult of the Palms to change batteries. Go to: http://forum.brighthand.com
Navigate to the Zire 72 section and read the posts. There are even detailed photos and uTube movies that deal with changing the battery. I have used their forum for years. Lots of help there.
Posted on Jul 20, 2009
Anonymous
SOURCE: COMPATIBILITY
not have passwort of tugsten E FOR SINCRINICE WITH HOTSYNC
Posted on Nov 18, 2009
Palm zire 72 will not syn with pc running win 8.1
You find a fix to that problem, and the (Palm) world will beat a path to your door. HP, Palm's new owner, has attempted a fix for Win7, but Win8/8.1 may become the impossible hurdle.
Mar 30, 2014 | Palm Zire 71 Handheld
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
Zire 72 resets on its own
Hello.
First, if you have not done so, perform a soft reset then a hard reset, if still a problem.
If a problem after the resets, your battery is most likely the culprit. I'd suggest to remove / insert or totally replace the battery.
If you are comfortable disassembling the Zire 72, here are some instructions found online:
http://www.macslab.com/charlies/Zire72Batt.html
Hope this helps.
Dec 31, 2009 | Cell Phones
My PalmOne zire 72 screen is frozen on the real player screen and nothing was playing. Empty. I had just tried playing off a mem card. I thought it would read and play card? I'm a tech idiot!
Normal 0 The best thing to do is to go to the free palm chat service they offer. I have used this and it worked good for me. Here is a link to the free chat service. Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
Now for the link......
http://kb.palm.com/wps/portal/kb/na/zire/72/unlocked/supportservices/page_en.html
Nov 27, 2009 | Palm Zire 72 Special Edition Handheld
May 30, 2009 | Palm Zire 72 Handheld
My Palm Zire 72 tumbled into two inches of water.
It seems that unfortunately you PDA is damaged and needs professional repair service, or just forget about it and buy another one.
Water causes to have corrosion and shorts in electronic devices, even if is dried internally (residues cause the shorts), which is an quemical effect of have water (or moisture) with copper and other metals and a voltage from the battery.
If anyway is already damaged, you may want to try in repair it yourself.
If so, you will need to open it, and remove all residues (kind of green or white dust over the components) from the copper traces, connectors and components.
If the event is recent, there is the chance you can clean it completely, but I do see that this happened a couple of months ago.
If several weeks (or months) passed, then a deep corrosion already took place in it, and is likely that the components and connections have been permanently damaged.
In order to open and repair, you will need:
1. Torx scredriver and philips screwdriver
2. Plastic pry tool to open it without leave marks or damage the PDA housing
3. 5X magnifier with light, or better if you can use a microscope, so you can review all the areas (including under the tiny electronic components) and clean them.
If you send it to repair, it will be expensive, and it may be over the cost of buy an used PDA but in good working conditions.
I mean, depending of the damage caused by the water, it may be necessary to replace one or all the major components inside the PDA (mainboard, LCD screen, speaker, camera, battery, etc).
Best regards,
May 25, 2009 | Palm Zire 72 Handheld
Ready to change battery in zire 72s
Here is a video I found on replacing the Zire 72 battery. I hope this
helps.
Mar 26, 2009 | Palm Zire 72 Handheld
AHHHH!!!!
Just had the same thing- I blew out the plug port and re-plugged it in, charged for an hour, and now it turns on.
Jul 12, 2007 | Palm Zire 72 Handheld
Zire 72 does not recognize the SD card
Have you used this card long and what size is it?
Jul 11, 2007 | Palm Zire 72 Handheld
Fatal exception error
hold down the up button and use a paper clip or tip of your stylis to reset, do both of these at the same time.
Aug 08, 2006 | Palm Zire 72 Handheld
Palm Zire 72 Special Edition Handheld Logo
54 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
