Question about GE Nautilus 24" Built-in Dishwasher
On our GE Nautilus Model No. GSD3400G00CC dishwasher, water is not going down the drain after a wash. We were away for a while and our appliances and pipes were all winterized properly, however, I have a feeling something is clogging the drainage - What do we do? Thank you very much for responding - I naturally cannot find any directions for troubleshooting manual. D. Marlowe
Posted by dmar268 on
5 Related Answers
Anonymous
  • 159 Answers
SOURCE: GE Nautilus Dishwasher - NO water coming in at beginning
all fill cycles on a dishwasher is timed. so at the end of the fill cycle the dishwasher may run. the first thing I would check is to make sure the water inlet valve is good. for this you will need a volt/ohm meter. you will want to make sure that there is 120v going to the valve. if there is you then would want to remove the wire connector on the valve and ohm it out. if you get a reading anywhere from maybe 450-650 the valve should be good and you will want to check for a blockage. good luck
Posted on Aug 04, 2007
Anonymous
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Posted on Nov 11, 2008
Anonymous
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
Anonymous
  • 170 Answers
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
Anonymous
SOURCE: water in bottom of GE Nautilus dishwasher
I was having the same problem and downloaded a copy of the manual and found out it is normal for a couple of inches to remain in the tub! I can't remember where I downloaded the manual, but you can "Google" it like I did. Hope this helps :o)
Posted on May 19, 2009
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
My GE Nautilus dishwasher keeps PUMPING water "out" of the machine during the entire wash cycle. I have removed all covers in the bottom of the unit to see if anything is stock. Used vinegar and CLR to...
If this convert-able dishwasher is permanently installed, you will have to take off the lower access panel to get to the pump area. If it is still in a portable configuration, it may be easier to lay the dishwasher on it's back or side to do this. Now, examine the pump / motor assembly. There is not a separate water pump on this model. There is a diverter pump out solenoid which get's pulled down to direct the water out the drain hose for pump out, which is suppose to spring back out of the way to allow water to go up to the spray arms for washing. I suspect that the solenoid got to hot and the plunger will no longer slide in the solenoid. If this is the case, you can replace it with a WD21X802. If the arm and plunger move freely, check the spring, or for obstructions in the pump housing, or possibly the diverter arm in the pump housing has come loose from the shaft. The solenoid is the most likely.
Apr 29, 2009 | GE Nautilus 24" Built-in Dishwasher
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher Start Problem (no water filling)
Model # should be on inside of tub wall....but any way...
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Mar 01, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher Start Problem (with no water)
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
2 year old GE Nautilus dishwasher
Check the pump, make sure it is working properly and pumping water out. If it is then check the drain hose and make sure it is not plugged.
Feb 11, 2009 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
171 people viewed this question
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
