1 year old samsung 50b550 1080p 50inch plasma...working fine one minute then screen went black, audio is ok. menus do not come up either. audio changes with channels ok. Have back off, capacitors look ok, ceramic fuses are ok, dont see any burnt spots on boards. could someone please help me with troubleshooting this problem?
Posted by johnwendell3 on
Sometime Mechanic
    Habit-Forming:
    Scholar:
  • 122 Answers
Samsung has three board. The power board is the one on the right and is where the 120 volts plugin. There should be only one capacitor rated at 100 uf at 450 volts. Measure this voltage - should be 390 volts. If not, change this capacitor to 350 uf with a rating of at least 400 volts (to 450 volts). I was lucky to have a old microwave and a old power supply laying around the house. I have a 120 uf and 220 uf both rated at 400 volts, and when I connected them in parallel (370 uf) and changed out the old one. The TV works fine now.
Posted on Nov 24, 2017
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Posted on Feb 21, 2009
Anonymous
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
Anonymous
  • 1077 Answers
SOURCE: i have a 50inch plasma tv green light go on for a
You must have some electronic experience when you replaced the bad capacitors.
Best thing to do is find a Service Manual for your TV on the internet. It will really help you in a big way to diagnose the source of the problem. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20.
Another thing you might want to look at is the power supply for the screen. Most manufactures call it a Backlight Inverter Board. The TV maybe trying to power up the screen and failed. Then, when into protection mode. The Service Manual should define the red light blinking code for you.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
Anonymous
  • 458 Answers
SOURCE: Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
Posted on Aug 13, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 27, 2009
Testimonial: "thank you sounds greek to me and costly but I guess I have to do what I have to do-----have you ever heard of a video IC board?"
Why is my screen black, but my audio is fine on my samsung plasma tv? Could it be the capacitors?
Sustain fault. Contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 18, 2014 | Samsung Televison & Video
47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
May 05, 2011 | H&B HP5500V Plasma TV
We have a 42" Hewlett-Packard
Y Board is out. The boards costs about $150 and easy to install.
Mar 12, 2011 | HP PL4260N 42 in. Plasma HDTV
Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
Screen went half black then full black
Sounds like a common voltage adjustment with samsung plasmas,I would call a service center these are things if you dont have experience you shouldnt attempt yourself
Apr 26, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
