SOURCE: Toshiba Satellite A205-S5804
Download the 8187b drivers from Realtek's site. You then need to go in and edit the .inf file to read like this:
;; IDs for 98SE/ME/2K/XP
[Realtek]
%RTL8187B.DeviceDesc% = RTL8187B.ndi, USB\VID_0BDA&PID_8197&REV_0200
%RTL8187B.DeviceDesc% = RTL8187B.ndi, USB\VID_0BDA&PID_8189&REV_0200
After the edit, install as usual from the device manager.
SOURCE: hard disk help
Hi
I have Satellite A205-S5804
Im try to download wendows xp to my lap top
Iwas do it successful
But I cant find any driver for my lap top
Like vga –Ethernet- sound-display-wireless
Plz can u help me
SOURCE: need RAID driver for toshiba Satellite A205 S5804 changing OS from Vista to XP...please help
copy & paste in your address bar:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1909174&rpn=PSAF3U&ct=DL&BV_SessionID=@@@@1043376847.1216644502@@@@&BV_EngineID=ccchadeejjelidhcgfkceghdgngdgmn.0
SOURCE: Toshiba satellite a205-s5804 laptop will not start
Hi, there are a couple of possibilities:
1. If you are able to start the laptop on battery then the dc connector on the motherboard may be broken or have come loose, in which case take it in for repair.
2. The power switch may be broken, again take it in for repair.
3. Tip of the trade: Disconnect the battery and plug in the charger, see if it will switch on. If not then put the battery back in with the mains still plugged in and see whether it springs back to life.
4. Tip of the trade 2: Leave well alone for a couple of days without any battery or power connected then plug back in and see if it will switch on.
Removing the BIOS memory, don't know where you saw that but not recommended at all unless you want to render your laptop completely useless. Don't attempt to strip down unless you are technically experienced with disassembling a laptop.
SOURCE: my toshiba a205 s5804 is asking me a bios password
There is a known issue on this model (A205 and A215) and Toshiba knows about it. A
password can be automatically be set by the computer and will need to
be removed and have the BIOS updated so it won't happen again by an
"authorized service provider." You can locate your closest Toshiba ASP
at support.toshiba.com This is a known issue and Toshiba knows about
it. You should get this covered at no charge if you take it into an
ASP, make sure to verify this with the ASP and take it somewhere else
if they tell you it will cost you anything. Toshiba will cover this
till December 31st 2010.
Toshiba Customer Service # is 1-800-457-7777
