Question about Westinghouse L1975NW Monitor
Westinghouse L1975NW monitor problem
Just opened my new monitor, had it going and was trying to get the screen to fit better and was pushing all kinds of buttons and hit the no signal input and now there is no picture at all and I can't get it off the no signal input. The reason I bought a monitor is because the backlight on my laptop died and I thought I'd hook up a monitor until I could figure out what new laptop I wanted to buy. Help me please with the "no signal input" problem.
Posted by cganem on
  • Anonymous Aug 13, 2008
    i had the same problem, had to disconnect my radeon graphics card, power up with the integrated one, got video, then reinstalled my graphics card and hooked up the new monitor. works okay now after many frustraing hours. Think you could maybe try powering up and hitting F1 to go to set up before the windows startup and check the video settings.
5 Related Answers
skotkolr
Scott Hill
  • 558 Answers
SOURCE: Huge Voltage Spike Blew the Monitor Board
most USA monitor boards are set for 120 volt at 60 cycles you are using 240 at 50 cycles in India and most moniotrs are not changeable like a computers power supply, so no you can't buy another board here and expect it to work, unless you have an electric transformerconverter to convert 240 to 120, and change the cycles then it will work and if you need a board you can ebay the monitor and ask one of the sellers if they have access to internal boards for replaccement. Now even if you buy a board here in the us, that doesnt mean you have a working lcd monitor, most likely you have done massive damage to the transistors in the lcd panel iteself I would be surprised if you did not have 100 dead pixels if it even worked at all
I would have it repaired there 9india) the cost is cheaper as the boards come from Taiwan...less distance to travel you see?
That is the best I can do for you have a great holiday season.
Posted on Dec 03, 2008
Rickajho
SOURCE: audio and picture quit working on white westinghouse lcm-17v8
If you haven't figured it out yet through a web search, Westinghouse monitoris have problems with blown caps on the power supply board. If you are lucky the problem is minimal and won't require more than replacement of the caps. You won't know until/unless you open the case and inspect the power supply board.
Posted on Mar 07, 2009
Anonymous
  • 152 Answers
SOURCE: buttons on the bottom of the westinghouse monitor
momof3boysn1, Did you try removing the plug from the outlet strip and then plug monitor back in and turn it back on? Usually the button that looks like an asterisk with a small circle dead center will be the brightness control. get back to me if this won't help. I'm louie12fix on fixya or [email protected] aol.com
Posted on Apr 05, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: DVI-D cable not working with Westinghouse L1975NW...
If the monitor has two video inputs - a DVI-D and a DSub VGA then the monitor needs to be switched to the DVI-D video input.
Posted on Jan 26, 2010
westytech
vidal chavez
  • 120 Answers
SOURCE: Sound for Westinghouse L1975NW Monitor does not
Hello, I wuld love to help you out a bit more but I need some more information so we can troubleshoot. You can contact me at [email protected] so I can further assit you.
Posted on Jan 28, 2010
PL191M works for 10 seconds, then goes off with small green light blinking. If I turn it off and back on again, it works for 2 seconds and goes back off. The owner's manual says to push the upper...
There is a couple of possibilities and things to eliminate.
Your monitor is acting like it's not getting a signal. First make sure your video cable is plugged in and tightly connected with the screws fully torqued down. Test the video card by wiggling the connected cord to see if the monitor comes on even temporarily. Try opening the case and re-seating the video card.
If you can get the monitor to stay on long enough go into the control panel and the properties page and make sure you screen saver or power management for energy savings is not set to zero.
If it's new you may have to go the your control panels add remove components and un-install the video card then re-install the driver again. Windows is famous for this requirement.
If you are using this as a second monitor connected to a laptop you will have to hit the corresponding function key on the top row of your keypad, F4 or ?...., to open the port to avail the signal.
On a mechanical level at the monitor depress the Menu button and try a few sizing adjustments to bring the picture back to shape.
Cable - HDMI, USB, VGA ? You may need an adapter to get the signal VGA to HDMI etc.
We need more information but try these things to start.
  • New Monitor
  • 2nd Monitor for laptop
  • PC or Mac
  • Type Cable
  • What happened when it quit working
  • Has it ever worked.
Let us know how we can help further.
TF
Sep 16, 2011 | Planar PL191M 19 in. Flat Panel LCD...
Got moniter working but screen is too wide for monitor i have to usw cross arrows to read the whole page
Each monitor has settings buttons on the front or side of the monitor to set the screen size, brightness, etc. Look for a button or wheel and find the menu, then go find the screen sizing, but verticle and horizontal and move it so it fits the monitor screen.
Pushing buttons on the monitor will not cause any damage, so try then all until you find the menu button and then you will need to find the button or wheel that moves you from selection to selection. Generally, pushing the menu button will select the highlighted menu item so you can adjust the settings.
I hope this was helpful.
Brian
Dec 24, 2010 | Computers & Internet
Hi, I have a philips monitor serial no: TY 64985283 and messed something up in the menu options that has caused the screen to continuosly scrool like a movie wheel. Can you please tell me how to fix?
I don't know your model so I'll try to guide you without that. Push the OK button and scroll using the up - down of the monitor buttons to go to reset. In case of asking yes - no push ok again and choose yes. Press ok again and exit.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 03, 2010 | Philips Computers & Internet
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
Menu stays on screen all the time and wont go off even when pressing buttons .Off On button doesn,t work either.Could cig smoke gum up buttons
Cig smoke wouldnt effect the buttons, the control board on the monitor is probably bad, this is what tells the monitor to display the menu, make changes, etc... If that has gone bad, pushing buttons would have no effect. Youre probably better off buying a new monitor.
Jan 20, 2010 | Computers & Internet
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Jun 02, 2009 | ASUS VW192S Monitor
DVI won't work
WOW! I have that monitor too on one of my systems!
Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why?
I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that...
I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO?
PLEASE let US know if you found a solution!
Anthony
Dec 12, 2017 | Samsung SyncMaster 214T Monitor
15in dell monitor model e151fpb
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Dec 07, 2007 | Dell E173FP 17" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Westinghouse L1975NW Monitor Logo
469 people viewed this question
Top Westinghouse Computers & Internet Experts
ByRuss
Level 1 Expert
efs_perpends
efs_perpends
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
